DFI Mobo C1 Error
Discussion in 'Tech Support' started by Joes2silly, 11 Jul 2008.
  1. Joes2silly
    Joes2silly What's a Dremel?
    21 Jul 2006
    Okay, I got a new DFI Lanparty DK X48 T2RS motherboard and got everything installed but when I finnaly when to boot it up it showed the "C1" error code on the diagnostic LEDs and I found out that it was the RAM. Im trying to boot it with 2 512 MB sticks or generic DDR2 800 RAM, could these sticks not work with the motherboard? Or did I somehow fry them?
  2. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    try getting it to start with only 1 stick, or if you have another pc test each stick with memtest.
  3. Krikkit
    21 Jan 2003
    No need to start 2 threads about the same problem.
  4. Joes2silly
    21 Jul 2006
    sorry..... and I tested it with one stick, then the other... nothing. I may just get some different RAM because I don't have another PC that supports DDR2 memory :(
  5. mansueto
    31 Aug 2007
    Does it post without the ram in place? The motherboard have all the plugs plugged in?
  6. Joes2silly
    21 Jul 2006
    Can a computer even post without RAM? The computer dosen't post and I'm not quite sure the monitor is getting a signal...
  7. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
  8. Joes2silly
    21 Jul 2006
    Thanks, I'm trying that as we speak :D
  9. Joes2silly
    21 Jul 2006
    Okay, I've done that "Get rid of error C1" thing once and I still got the error code. If i still get the code does that mean that I have to RMA the motherboard?
    EDIT: I've done this twice and I still get the "C1" error. So it is either the board or the RAM. Tomorrow I will try to test the RAM before dealing with RMA'ing the board
  10. BlueOcean
    BlueOcean What's a Dremel?
    5 Feb 2008
    your DFI Lanparty DK X48 T2RS very nice motherboard. Should not have problem. If you still have problem with the motherboard.You should call the DFI manufacturer. I hope the problem solve.
    http://us.dfi.com.tw/Contact/contact_us.jsp?PAGE_TYPE=US&INDEX_TYPE=MB&SITE=US
  11. Joes2silly
    21 Jul 2006
    I'll try contacting them but I think I have to RMA the motherboard :(
  12. Joes2silly
    21 Jul 2006
    I found the problem! Its not the mobo! No RMA! W00t! Sorry.... I figured out that the RAM speed is not even compatible with the motherboard so I'm positive that I need new RAM :D (I'm happy that the motherboard is functional, not that I have to spend more money)
    I have two units on newegg that I'm looking at, a 4 GB unit from G.Skill and a unit from OCZ. Which unit should I buy?
  13. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I thought all RAM was compatible with all boards. If the board doesn't support the speed, it'll automatically set it to the max it supports.
    I guess it isn't possible to get to the BIOS setup if POST doesn't complete? If you are able, make sure that every setting is right (voltage, timings, FSB:Memory).
  14. chrisb2e9
    18 Jun 2007
    isn't it just ddr2 800mhz ram that you are trying to put in? that should work with and ddr2 board.
  15. Joes2silly
    21 Jul 2006
    Its DDR2 555/400, I don't know why I thought it was DDR 800
