Windows Diablo 3 - good, bad, decent?
Discussion in 'Gaming' started by MageOutlaw, 23 Mar 2013.
  1. MageOutlaw
    MageOutlaw What's a Dremel?
    3 Apr 2006
    Despite being a semi-big diablo fan iI have been unable to play D3 (Afghanistan is a bit*h lol). howevere I have been looking at it since it came out and I have a few question about the game.
    1)how is the game play Iv seen mixed reviews both good and bad.
    2)is the monk class as bad as iv read?
    3)if the monk an ok class can they dual shields to maximize the defenc/dex boost?
  2. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    I've played it briefly at a friend's place, so I can only answer question one:
    I'd say Diablo 3 is a decent game :D More leaning towards good than bad :)
  3. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    i had much more fun playing Torchlight II.
  4. rollo
    rollo Modder
    16 May 2008
    Diablo is great till inferno after that its a gear grind.
  5. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    It's a great game mostly. I hated the boss fights though, cut scene after cut scene to make them longer. Much prefered the way it works in most other games: When the boss has no health left it dies.
    The social aspect of the game is great though, the private loot and the way instances and party play work are awesome.
    May I suggest Path of Exile, it's free and very good as well imo, but much harder.
  6. Harlequin
    Harlequin Modder
    4 Jun 2004
    buy it on a PS3 lulz
  7. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    The general opinion AFAIK is get Torchlight II instead.
  8. rollo
    rollo Modder
    16 May 2008
    buy both its what i did.
    Diablo 3 has a much better story than torchlight 2. for what its worth.
    but you can mod torchlight 2 and it becomes a lot of fun.
  9. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Diablo 3 is a better game than TL2 in my opinion, as it generally has higher production values and I stopped playing TL2 after my first run through, whereas I played diablo 3 through I think 4 times.
    However, it does become very much a gear grind at the higher levels, so I tend to just make a new character at around lvl 40.
    Probably the best thing about the two of them is the experimentation that takes a long while to 'perfect'.
  10. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Not as silly as you might think. The ps3 version sounds like its going to be better than the pc version.
  11. fdbh96
    29 May 2011
    It doesnt look like its going to be straight port, and the couch mode sounds pretty cool too. Have they said wether it will have the RMAH?
  12. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Supposedly no RMAH but i can't remember where I read that.
    IMHO, Diablo 3 is junk. Played Diablo 2 to death, with maybe 20 different characters and builds. I haven't even completed a single run through on D3.
    Does seem like a good local co-op PS3 experience though, and may get it just for when my mates are over and we want to trash some ****.
  13. koola
    koola Minimodder
    11 Jul 2004
    PoE is where everyone from D3 went to.
  14. Kiytan
    Kiytan Shiny
    2 Jul 2009
    yeah, if you want a hardcore and versatile ARPG, go for Path of Exile, if you want a slightly more relaxed game, go for TL2.
    Diablo III is really fun for the first run, but after that it gets rather dull (especially at inferno, where it's basically grinding money to upgrade gear at the AH)
  15. rollo
    rollo Modder
    16 May 2008
    Poe been still beta makes it difficult to recommend as you will have to start again come release.
  16. fdbh96
    29 May 2011
    Found it:
    http://www.tomsguide.com/us/Diablo-III-PS3-No-RMAH-Trading-Auction-House,news-16881.html
  17. Kiytan
    Kiytan Shiny
    2 Jul 2009
    They're not wiping characters between Open beta and release.
  18. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    My beta characters are all available in the retail version. Just had a passive skill reset :D
  19. Vajra
    Vajra What's a Dremel?
    27 Jul 2010
    The game is not too bad. It has been dumbed down a lot which is a bit lackluster.
    However the game is still fun to play and definitely worth the time, at least in my opinion. However it doesn't have as much replayability as D2.
  20. GuilleAcoustic
    26 Nov 2010
    To be honest, a good old Street of rage on Sega Genesis / Megadrive gives me the same than D3 ... it's fun to smash mobs, but it's nowhere near D2. What has been revealed from the incoming extension won't change it. LOD added far more things, in fact it completly changes the game and made it shine.
