Diamond Plate Cable Modem
Discussion in 'Project Logs' started by rocketnick, 10 Feb 2005.
  1. rocketnick
    rocketnick What's a Dremel?
    10 Feb 2005
    Okay, hi everybody. Ive drooled over Bit-tech case mod for a year now, but I had only been posting in a different forum. However i happen to think bit-tech kicks @$$ and i want to try to contribute. Okay back on topic
    Meet the cable modem mod. definetly still in progress. The inspiration from this mod came from a friend of mine, you might know him as ATI Loyalist. Anywho, i am taking my rather bland looking cable modem and i was bored, so the idea is this
    I will be using to extra Black Lian Li cd bay covers i had around as the end caps to a new enclousure for my CM.
    And i will be using aluminum diamond plate to finish everything between the two lianli face plates. However this is where i need help. I cannot find the correct hardware to mount the lian li face plates, and the diamond plates, and the CB PCB. so, i will post a little paint diagram as soon as i can
  2. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    You need to post some work in progress pics pretty soon before this gets moved to modding...other than that, it sounds like an original idea, good luck :)
    <A88>
  3. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    yes we need some more pics and for your question you should use some metal to metal type glue cant think og one at the mment but you should use that you attach the blanks or you can just drill and thread some holes for mounting it
  4. rocketnick
    10 Feb 2005
    Okay, finally an update
    I bought this diamond plate at a place called Capitol Metals in downtown Phoenix for 28$, a steal IMO
    Here you can see that i have used some angle aluminum, also from Capitol Metals (5$) I used it in between the Lian Li covers to creater the frame where i will mount the diamond plate onto. You can also see the holes drilled and filled for the cable, power, and cat5
    Socket Head Cap Screws = Win
    Heres the victim cabel modem PCB, *sigh* it looks so naked
    This is the teaser i leave you will till i can update again
  5. mobius9
    mobius9 Minimodder
    4 May 2004
    I have that same drill press... never knew you could hang the little chuck tightener there though.
    is it themed around a case you have, or is this something totally different?
  6. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    This looks Promising!
  7. CaseyBlackburn
    27 Jul 2004
    Is it just me or could those be female ide things and the closest one to the camera looks like it would be for a COM port
  8. planki
    planki ...
    20 Dec 2003
    i would have to agree they do look like female ide ports dont know why a cable modem would have female ide ports though but the com one could be for flashing the firmware etc
  9. rocketnick
    10 Feb 2005
    yeah, i noticed those things, i havent the fogiest what their for, but they are to small for standard IDE, it might fit a floppy type cable, im not sure
  10. rocketnick
    10 Feb 2005
    oh and @mobius9 yeah this is just totally random, but i think i might do all of my networking equipment in a simmilar way. That would look quite cool i think
