Diein' PSU, need a new one, ADVICE
Discussion in 'Hardware' started by 1398342003, 20 Jan 2003.
  1. 1398342003
    1398342003 Ubermodder
    2 Sep 2002
    :waah: :waah: :waah: The PSU in my good rig has bad cables. Like really bad. I can tap the ATX cable and the system restarts, and several Molex connecters are bad.
    So I need a new one. THAT HAS GOOD CABLES. I know of the brands, I need to know what your suggestions are. I've got a budget of cheap is better.
    I'm in Canada, so the retailer should be on the same contenent,
    It must be under $200 local currency, (CAD) with shipping,
    400 - 450 Watts (not max but desired)
    Preferred:
    Vantec
    Zalman
    Antec
    Enermax
  2. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    Sorry to be a cheap ******* but why don't you just solder some new cables on? :)
  3. 1398342003
    2 Sep 2002
    And replace 6 Molex, 1 ATX, and the misc connectors?
  4. xen0morph
    30 Jun 2002
    Don't see why not, just strip down a very cheap or dead PSU and solder the new wires on.
    Make sure you get them in the right place though :D
  5. 1398342003
    2 Sep 2002
    I'd need an old PSU for that. I'd really hate to make something else in my case work poorly.
  6. Adam
    Adam Minimodder
    26 Jan 2002
    Q-tec 550w is hard to beat if you're on a budget. The cables have been fine for me.
  7. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    I can only reccomend Antec True power or a sparkle psus...both work flawlessly in my systems...
    wouldnt get an enermax as they often have been reported to have bad 5v lines...
  8. Trebor95
    Trebor95 What's a Dremel?
    20 Jan 2003
    Personally I use a modded Sparkle PSU and find that once I tweaked the pots the 5V & 12V lines are extremely stable.
    However, for a budget purchase the QTEX 550W PSU's are very hard to beat )as Adam has said already :)) and I have heard many good things about them, very stable and a decent build for the price, however a liitle on the loud side, but you can just take the fans out and just stick one exhaust fan in there (papst, panaflo, ystech, evercool etc. etc.)
    HTH
  9. 1398342003
    2 Sep 2002
    One other question. Where to buy? Pref in Canada.
  10. 1398342003
    2 Sep 2002
    Anyone?
