Apple Difference Between apple MAC address and PC MAC address's?
Discussion in 'Software' started by seebul, 20 Apr 2007.
  1. seebul
    seebul Minimodder
    9 Aug 2005
    Just wondering wheter MAC addresses from macs are different to that of pc's? Would you be able to tell just by looking if an address was from an Apple Mac?
    Thanks guys
  2. Cabe
    Cabe What's a Dremel?
    14 May 2002
    MAC Address (or BIA - Burned In Address, so called because they are set in the firmware) is a term for a unique identifier for your network card. They are in the same format reguardless of your manufacturer. Most of the time they are shown as 6 groups of 2 hex characters, cisco being cisco usually show them as 3 groups of 4 characters.
    http://en.wikipedia.org/wiki/MAC_address
    Whilst you couldnt tell if it was an Apple Mac or not you can usually pull the manufacturer out of the MAC because the first 6 characters are the manufactures/device ID.
    http://aruljohn.com/mac.pl if you fancy having a look at yours.
    In short no, they arnt different, and unless Apple have thier own manufaturer code, no you wouldnt be able to spot it was a Mac.
  3. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    they have different numbers.
  4. Cabe
    14 May 2002
    Thats the idea of a unique address yes ;)
  5. Fod
    26 Aug 2004
    well, duh. sarcasm my good man.
  6. seebul
    seebul Minimodder
    9 Aug 2005
    Ah thanks for that cabe, i didnt know the first numbers were for the manufacturer. Basically wanted to know because a teacher is accusing me of something that happend to one of the school servers... he says it was an apple MAC address and since im the only one with a mac ive got the blame:( :wallbash::wallbash:
  7. Fod
    26 Aug 2004
    ok so looking at the MAC address of my macbook pro's ethernet adapter, the first 3 bytes are 0016CB.
    even though apple use a variety of networking adapters it appears that (according to this: http://standards.ieee.org/regauth/oui/oui.txt) the MAC addresses are indeed coded to Apple Computer.
    so, it looks like you're screwed.
  8. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    its not like its impossible to spoof MAC addresses, most NICs have an option for you to set it manually so its more than possible to clone an apple machine's address...
  9. hobbs
    hobbs What's a Dremel?
    24 Jun 2005
    if you didnt do it, just show him your mac addy and they wont match up, so it cant be you..
  10. seebul
    seebul Minimodder
    9 Aug 2005
    Ok thanks for all the reply's guys.
    Yeh well hes checking the address on monday i was just wondering if he was lying about it being an apple MAC address.
