CPU Difference between athlon x2/phenom x2/x4 in gaming?
Discussion in 'Hardware' started by featherz, 13 Apr 2010.
  1. featherz
    featherz What's a Dremel?
    21 Mar 2010
    Still getting all my bits together for my budget gaming build, being on budget i was wondering if i was to by a x2 3 ghz athlonII how would it compare to say phenomx2/x4 II in gaming??
    Thanks, for your info will be paired with a 4870.
    EDIT looking at 550 BE with MSI 770-c45 and 4gb of corsair ddr3 1333 memory
    Vs
    Athlon II X4 630 with same board and memory combo
    Vs
    550BE with MSI 77-C45 and 4gb of corsair ddr3 1333 memory but with also the pro 7 arctic cooler revision 2 and mx2 thermal paste for prety much same price as the athlon II combo.
    Price difference the athlon combo costs 20 pound more.... what would you do?
  2. rollo
    rollo Modder
    16 May 2008
    amd 250 x2 thing is fine
    you wont notice any diffrence
  3. unknowngamer
    unknowngamer here
    3 Apr 2009
    It may be worth a note, if you get a 750/751 southbridge, sometime you can unlock a dual core.
    I got a AMD Phenom x2 555 for £60 of ebay.
    put it in a M3A78-T (£45 today deal, scan).
    20 seconds in the bios and, Bobs your uncle, a quad core B55 @ 3.9 GHz.
    not bad for £100.
    Not all wil unlock and overclock like mine, but with carefull selection of components you can increase the odds of a £100 FREE upgrade....
  4. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
    I'd go with the 550BE and see about unlocking some cores, even if you can't manage 2 cores a triple core, overclocked to say 3.8Ghz would be better than the quad core for gaming.
    Although you can overclock the X4 630, going past around 3.2Ghz will give no noticable benifits as the lack of L3 cache means instructions cant be fed into the processor any faster than this where as with the 550BE with it's L3 cache, will see much bigger imporvements through overclockng.
  5. featherz
    21 Mar 2010
    That MSI board i specced can unlock cores?
  6. Xonar
    2 Nov 2009
    It can ye
  7. featherz
    21 Mar 2010
    Thanks will go for the 550 BE cheers will rack your brains when im overclocking/unlocking cos im new to this :)
  8. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    550 BE is a great investment, unlocking is easy is your MoBo supports it, just one click. As for OC is is a vary stable Chip and OCs nicely.
  9. Cosmot
    Cosmot What's a Dremel?
    12 Apr 2010
    I support 550BE, at least much better than the 7750, estimated that it release 4 core first.
  10. miester7
    miester7 My single core cpu plays crysis
    13 May 2010
    The x2 555 is better due to c3 stepping!
