Modding Diffusing LEDs
Discussion in 'Modding' started by Fly, 9 Feb 2003.
  1. Fly
    Fly inter arma silent leges
    31 Aug 2001
    I need to be able to Diffuse a white led to act kinda like a bulb and not a spot... what is the best way to do this with a standard 20 degree viewing angle LED? Is sanding the LED surface effective? want to know of your experiences before I paper a 3 quid LED for nothing!!!!
    Or do you have perhaps another solution?
    Thanks
  2. linear
    linear Minimodder
    5 Oct 2001
    Sanding is effective. If you like, you can aim it into a piece of acrylic (hell, anything clear) that you sand instead.
  3. Fly
    31 Aug 2001
    wow, prompt answer at 4 am!!!!
    hmm... the thing is the LED will have to fit into something solid and nearly seethrough so I'm hoping sanding will suffice.
    cheers m8...
  4. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    How about spraying it with glass frosting?
