It is done, a final version of a guidance "HowTo" is available now for the Download. Here you can find some pictures and a detailed desription the main characteristics in the overview: - Micro-controller digitally regulated fan/temperature-control, regulation works 100% independently of the operating system (e.g. Windows...) - with up to 8 sensors the temperatures of the PC's are monitored and the speed of the fans are adapted automatically - very exact temperature sensors with a accuracy of 0,1°C (DS1820) - several safety functions protect against the overheating of the computer hardware - low-loss control of the fans by pulse-width-modulation (PWM), saves energy and produces no additional heat - the fans can be regulated within a range of 40% to 100% - The fan's speed is also shown in PWM mode, over the whole work area - USB-interface - suitable also for watercooling - display of all values on LCD 1*20/2*20/4*20 (temperatures, fan's "rpm", alarm status...) - simple operation over only 2 keys - very flexible configuration possible (alarm temperatures, sensor-fan config, hysteresis...) - storage of all settings in eeprom
Here you can find a first translation of the description. But it is partly translated automaticly because my english is not so good. Projekt "Fan/Temperature-controll with USB-interface. If you find some mistakes (and i think you will ) please write it to me. Maybe someone also can help can help me in translation, please. greets KeiAng
Thanks! I was just about to start working on something like this for a external watercooling system I'm storming right now This gives me a great start! I'll still need to add some pump control, flow monitoring, etc. Interested in working together on this?
Wow, excellent job! Been looking for something like this for a long time. Extremely detailed instructions as well! Weiter so!
If someone are not able to connect to my website and want to get the "HowTo built this Fan-Control", please simply send me a email to "rg256@gmx.de" with subjekt "HowTo Fan-Control" and i will send you the full archive containing a screenshot of my website, all plans and the HowTo.
this my friend is absolutely fab!!!! well done. i have e-mailed you asking about this in more detail, please could you find the time to reply. Thankyou and good job!!!! Snood Edit: i thought that RPM sensing didnt work on PWM controlled fans?
i will answer you in a few days, in the moment i'am a little bit busy with my exam it will work, but only under special conditions: - at first the fan have to be switched on/off at the 12V line and not at the ground line - it works only over ~50% of normal supply voltage (e.g. "12V fan" needs minimum 6V for working rpm-signal) - the switched power-line for the fan needs a good capacitor etc.
A "small" update of the project: 1.) Instead of a normal Text-LCDs (HD44780 etc.) also a graphics LCD can be connected now, with that some more information can be indicated at the same time. I used a GLCD with the controller "T6963C" (240 * 64 pixel) here. Here is a short video: Video of the GLCD (press button "Auf gehts" to start download) Description of the GLCD: Regulation with GLCD 2.) The software for Windows is now also almost ready. At this time all dates of the regulation can be indicated and adapted (temperature-, fan-, regulation dates as well as all configuration data: temperature limits, sensor-fan config, etc.). As next a small interface comes for the software "Samurize" www.samurize.com included, with that everyone can represent the dates graphical likes he want to. You find a precise description and even further information here: Windows Software The most important enlargement is to be let indicate all dates in a diagram. With that one gets a very good overlooks about the regulation behavior and with that whether all attitudes are correct. The diagram can be stored if required with a right click as a graphics file. 3.) With this enlargement bigger fans (>2W) or several can be connected at the same time. in total 6 fans with each 10 W can be connected. Description of the fan enlargement: fan enlargement
Just a short update of this project. I have added support of a new graphic LCD: graphic LCD during operation ( all data scrolling from down to upward ): the setup menue on graphic LCD: Mode choice by pressing switch: on this graphic LCD I have tested now a diagram function: short movie of diagram mode: download movie ( to start download click on button "auf gehts" ): graphic LCD -> diagram mode Link: graphic LCD with "SED1520"-Controller connected to fan control V1.4d
Ok here are now a final update of this project. I have reworked the hole Windows Software V1.8 and added many new feature. I have finished 2 extension for this project: - "8 channel light control" -> "8 channel light control" - "Emergency shutdown / alarm output / pump check" -> "emergency shutdown" extension: "8 channel light control" - With this extension can 8 additional light channels manages and to be programmed own light sequences. Here a short sample movie: light sequence. ( to start download click button "starte download" ) - it can be also showed the speed of a fan as bar graph or as a binary value - alle settings can be done in windows software: extension: "Emergency shutdown / alarm output / pump check" The emergency shutdown works in this case not over the Windows software but ove the connection "power switch" of the main board. Through that the emergency shutdown is independently of Windows and works much more secure with that. - With this extension the PC can in the alarm case shutdown or completly switch off. - In Addition there is another relay with that on the extension an additional fan or a pump in the alarm case can be activated. In the case of following alarms the emergency shutdown is activated: - temperature of a sensor rise over the defined value ( overtemp. ) - a temperature sensor turned out - rate of a pump or flow sensor lies under the defined value or completely breaks down
That is some very nice work. I can't believe I missed this thread after all this time. Wait, now that I think of it... I was in Washington D.C. on the initial post and in Taiwan the next update.
