Guide Dimensions for anyone making their own case
Discussion in 'Modding' started by DeX, 25 Jan 2003.
  1. DeX
    DeX Mube Codder
    22 Jul 2002
    The PSU dimensions are the second set of dimensions listed in my first post:
    ATX PSU
    H: 86
    W: 150
    D: 140
  2. iced98lx
    iced98lx Banned
    12 Mar 2005
    I can host whatever it is- just drop me a line!
    Chris
  3. Unlimited 1
    Unlimited 1 What's a Dremel?
    20 Jan 2005
    Does anyone have a template for the EATX form factor ?
    I need the measurements for all the holes for a EATX motherboard.
  4. windwakerfan
    windwakerfan Banned
    5 Jan 2006
    Hey what's the size of a average hard drive bays and a cd/dvd drive bay?
  5. McKaamos
    McKaamos What's a Dremel?
    12 Feb 2006
    Does anyone have dimensions for Low Profile expansion slots?
    Like, where you put your PCI and AGP cards, but in low profile form.
    I'd like dimensions and mountingholes for slimline CD/DVD drives too, as i'm sketching something in sketchup.
  6. xc3ll
    xc3ll What's a Dremel?
    31 May 2005
  7. Duke Raoul
    Duke Raoul What's a Dremel?
    19 Apr 2007
    Does anyone have the exact dimensions for a flex atx rear panel?
    I mean the size of the holes for the PCI cards and the I/O panel on the backside of the chassis.
    Unfortunally the link on page 1 of this thread seems to be dead...plus I'm not sure if ATX and flex ATX are using the same standards...
    Thanx a bunch,
    greetz
    D.R.
  8. identikit
    identikit Minimodder
    5 Jun 2004
    More than a year late, but hey better late than never.
    E-ATX, known as Extended (very important in Google search (Embedded likes to get into the results) should really be known more by SSI EEB form factor.
    http://www.ssiforum.org/ and the datasheet for EEB can be found here http://ssiforum.org/Electronic Bays/SSI EEB v3-61.pdf (200Kb PDF file).
    I'm currently modding a motherboard tray from ATX to EEB, importantly you need CPU mounting holes. Ie the heatsinks bolt directly to the chassis instead of being secured to the motherboard.
  9. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Here's a simple drawing with PCIe card dimmensions:
    PCIe Card Size
    If you want to know the works, the following link is for you.. here you got every PCIe dimension you'll ever need. It has detailed drawings of the card, connector (even pins and stuff), back plate, you name it:
    PCI Express™ Card Electromechanical Specification - Revision 1.0a (PDF)
    Check pages..
    • 54 - 56 for male/female connector info.
    • 68 - 75 + 81 for card + back plate info.
    • 79 + 80 for PCIe connector placement on motherboard.
    Enjoy! ^_^
  10. Xer0-
    Xer0- Waste of space
    26 Mar 2007
    from the pdf macro posted
    pci express cards
  11. motas
    motas What's a Dremel?
    7 Dec 2009
    Hey does anyone know where to get a 3d dwg or skp of a 10 pci e-atx mobo tray?
  12. jhanlon303
    7 Sep 2006
    Anybody have a design spec for a 26mm SO-DIMM card with pin spacing?
    john
  13. motas
    7 Dec 2009
    What is the length of a 5.25" bay plus cabling? I am designing a case with a seperate compartment for bays. Thanks.
  14. Spotswood
    Spotswood Custom PC case builder
    30 Jul 2007
    Slimline drive specification is here.
  15. aglaser
    aglaser What's a Dremel?
    19 Dec 2008
    Does anyone know the dimensions for an ATX motherboard backplate? the I/O area is in the atx form factor specification, but not the expansion card area
  16. sejutaluka
    sejutaluka What's a Dremel?
    23 Nov 2007
    yeah.. i need this too
  17. D-Mon Taurus
    D-Mon Taurus What's a Dremel?
    15 Mar 2011
    Ok my first post and i am hoping that you guys -girls to, I know you are out there- can help me out.
    Have an idea for a case and it is going to be my first, Now I have been searching the internet for almost a year for the right measurements of the back plate of the case. And it has been a lot of reading and comparing.
    Now I would like to ask you to help me with the drawing I made and tell me if the measurements are right. I am a bit of a perfectionist.
    I will change the numbers if needed and this will of course be for all to use as well. It is all done in mm, I hope that that isn't a problem?
    The right bottom corner where it says 4.1 mm is based on the use of a 6.35mm [0.25"] stand-of (most commonly used there is no standard)minus the distance between Motherboard bottom side and I/O shield. that distance is 2.23mm [0.088"]
    The right and left side are obviously open to change depending on hight of case the bottom will be where the top of the motherboard tray will be.
    As also shown there are no folding lines drawn so if you are using this take that in to account. I am trying to work out a template for Motherboard tray holes as well...
    Hope you all can help.
  18. Spotswood
    30 Jul 2007
    @ D-Mon Taurus - It looks good to me. :clap:
    It would be great if you would mark the location of the standoff that lands between the first expansion slot and the I/O shield cutout.
  19. D-Mon Taurus
    15 Mar 2011
    @spotwood. First of my thanks.
    The first standoff as you call it i am guessing you mean the part between the I?O shield and first slot.
    From what i read.
    The center of the first slot is located 0,5inch or 12,7mm from the I/O shield cutout. Knowing the slot is again a 0,5inch wide the rest will be the standoff. so that would mean a 6,35mm or 0,25inch.
    my main concern and the part i am not sure of is the length of the slots. The measurements you see here are made by looking at a bracket. same goes for the screw holes for the slots
  20. Spotswood
    30 Jul 2007
    From the PCI Express documentation. fig 6-2 ...the opening starts 10,16 from underneath the lip of the card bracket and extends downward 89,90.
    D-Mon Taurus likes this.
