Electronics Dimming leds
Discussion in 'Modding' started by cpemma, 19 Apr 2002.
  1. cpemma
    cpemma Ecky thump
    27 Nov 2001
    With a led across a fan connected to a rheostat or linear controller, you get a much better dim if you hook a few diodes in series with the led.
    Raise the Vf of the series (taking diodes as about 0.65v each) to just under the minimum fan voltage, with a resistor calculated to limit current to about 10mA at 12v. (Use a low If, brightness changes over about 10mA are less obvious.)
    The extra Vf greatly exaggerates the fall in led current with voltage.
    Five 1N4001 diodes and 470R on a blue Kingbright L934MBC led gave me:
    At controller max (10.9v)
    led drop - 3.0v
    diode drop - 3.4v
    resistor drop - 4.5v
    If - 10.9mA
    At min (5.1v)
    led drop - 2.4v
    diode drop - 2.6v (must get the meter checked :worried: )
    resistor drop - 0.1v
    If - 0.2mA
  2. linear
    linear Minimodder
    5 Oct 2001
    Clever trick.
  3. viridius
    viridius What's a Dremel?
    7 Apr 2002
    Good idea. Just make sure they are silicon diodes. Germanium diodes have a 0.3V drop.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Textbook claim, but a slight fallacy, the germanium Vf goes up fast to over 0.6v with a few mA flowing. Lowest drop at led currents is with Schottky silicon.
  5. Floydian
    Floydian What's a Dremel?
    30 Dec 2001
    Awesome, thanks for the info, I was hoping someone would come up with a way for LED's to dim in a nice fashion. Its hard to just use a resistor to make a LED dimmable with a variable Vf.
  6. viridius
    7 Apr 2002
    I stand corrected. What do you expect when you read military field manuals from 1981?
  7. mr. phantastik
    mr. phantastik What's a Dremel?
    7 Apr 2002
    Haha..military field manuals:
    "In case of enemy attack, follow following circuit diagram for safety..." :D
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    You're right at the low currents you get off an aerial (antenna), and that's where the germanium are best used. :D
    And the graph I found was in a 1980 book ;)
