Modding Dirt cheap colored plexiglas (US only)
Discussion in 'Modding' started by DistortedDesigns, 8 Mar 2005.
  1. DistortedDesigns
    DistortedDesigns What's a Dremel?
    6 Oct 2004
    I have been looking for someplace that sells colored plexiglas for a reasonable price and I have found it. Tap plastics can't come close on price. The only draw back is they only carry one size and thickness 12" x 24" 1/8" but for only about $8 - $12 per piece and shipping is very reasonable as well. They have a wide varity of colors, translucent, transparent, colored mirror plexi.
    http://www.sloanswoodshop.com/acrylic%20sheets.htm
  2. KidModder
    KidModder What's a Dremel?
    22 Dec 2004
    Sweet they hasve so many types of acrylic. WOW thanks. :thumb:
  3. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    Now someone give me a UK alternative :blah:
  4. DistortedDesigns
    6 Oct 2004
    LOL That is the fun part of these modding forums some in the US and some in the UK. Finding places across the puddle. :rock:
  5. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    UK alternative would be good, but the Belgium one would be BETTER.
    Anyways, not bad prices there. Might consider ordering, but is the place to be trusted?
  6. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Those looking for really nicely priced plexi in the US/Can should also probably check out www.delviesplastics.com, very cheap and fast, also cuts to size using lasers. All cell cast acrylic, too...unless you specially request the cheaper extruded (which you probably shouldn't do).
