Motors DirtDevil 750cc
Discussion in 'General' started by icutebluezone, 27 Apr 2010.
  1. Krikkit
    21 Jan 2003
    Aww, but if you cover 'em up you can't look at the epic shocks. :D
  2. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
    LOL. Thats tru but keeps the dirt and stuff out. :)
  3. icutebluezone
    6 Aug 2007
    Got this for xmas.
    Picked up a steering rack for the buggy. Will have it next week. Rack and Pinion Thin Line 11"
  4. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    Am I the only one who came into this thread expecting to see a vacuum cleaner?
  5. icutebluezone
    6 Aug 2007
    LOL. Crackup. :)
    Anyways did a little work on it today.
    Got Both exhausts mounted.
    The mounts
    Still got to take the exhausts off and paint with high temp paint.
    Welded and welded into the frame 1 of the front swing arm mounts. Is shiny as I just sprayed a coat of metal protector on it.
    Started stripping the rear shocks. Getting them ready to get sand blasted and recolours. :)
    Do more on the front this week. :)
    mvagusta likes this.
  6. icutebluezone
    6 Aug 2007
    Stripped all 4 shocks tonight ready to get sand blasted and recoloured.
    Will have more photos on weekend. :)
  7. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Awesome progress mate :thumb:
    Need to get me something like this to play with in the summer but my track toy Evo still needs a lot of work yet, have to fit the roll cage and stuff yet, all fun though :D
  8. icutebluezone
    6 Aug 2007
    2 more bits done tonight. Man it was fun getting the angles right. :)
  9. icutebluezone
    6 Aug 2007
    Tiny update on buggy tonight. Cutting the notch for shocks.
    Inlarged this at work today to full size. Make bending the pipe to right size easyer. :)
  10. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    After the front suspension, what else is left to do? I'm impatient to see this thing skipping dunes already!
  11. icutebluezone
    6 Aug 2007
    Firewall behind seat. panels on sides and bonnet. Wires for lights and engine and dash. and other little bits and bobs. :)
  12. icutebluezone
    6 Aug 2007
    Done a little bit on frame and frontend.
    Cut down flat.
    Holes fulled.
    Ready to make and install nerf bar plates on.
    Plates for nerf bars.
    Started on fulling in the notch.
    My steering rack.
    Going to work on finishing the notches in frame and the other frontend plates installed. also start on a mount for rack.
  13. icutebluezone
    6 Aug 2007
    Finished The notch in both sides of the front of the frame for the shocks.
    Also been drilling all the side plates. Still got to drill and tap the 1's with small holes.
  14. icutebluezone
    6 Aug 2007
    Not a update on buggy. Just waiting on parts to turn up for it. But I did put a graphic on both sides of my car. :)
  15. icutebluezone
    6 Aug 2007
    Just a little update. Front plates all installed.
    Top mounts bolted together and ready to install when i have made swing arms.
  16. Little_chef
    Little_chef Now with added custom rig!
    14 Oct 2010
    Just started reading this. Hugely impressive. I just hope that one day I'll find time to do something similar, but that'll be a while yet.
  17. icutebluezone
    6 Aug 2007
    Off work at moment because of the earthquakes. Sick of the shakes.
    But got some good news. :D Got my steering solumn bearings and steel for steering column.
    Have draw up the rack mount plate and got one cut out of MDF at moment for testing.
  18. icutebluezone
    6 Aug 2007
    Little update.
    Got the bearings for the steering column, Also got the steel for it this week.
    Made some more plates up. They are you in the rear of buggy for swing arms.
    Also got the calipar mounted to sort out the size of the spacers i need to make for it so that be me next job and look at starting a chain tensior.
  19. icutebluezone
    6 Aug 2007
    Got my package i was waiting for from AUS.
    And inside it was. Front disc's, brake calipers, 2 xtra sets of pads and 2 steering uni joints.
    Mounted the air box other day. Still got to install air filter.
    Tiny mod to the rear caliper. Removed the mounting hole tab off it that i dont need.
    Got the steel for steering column. Just test fitting.
    Going to do some more on it this weekend as I have 3 days off. :)
  20. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Good thing it has some brakes now ;)
