Networks Disable firewall?
Discussion in 'Hardware' started by friskies, 20 Nov 2006.
  1. friskies
    friskies What's a Dremel?
    17 Nov 2003
    Is it dangerous to disable the router firewall? If someone wants to hack me they need some kind of exploit right? They can`t just connect to my pc right?
  2. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    I don't see why you should disable your firewall. Your pc can be accessed by people no matter how many protections you put in place, it's just you should make them not have an easy target so they will move on to another. They need an exploit but some many are open in your OS so yeah, good luck.
  3. Glider
    Glider /dev/null
    2 Aug 2005
    Think about this: If someone wants to gain acces to your pc they will. You can make it harder for them to get in, but they will eventually. Now, with that in mind, what do you have on your pc that anyone would be intrested in? Except use your PC as a Proxy or relay? Probably nothing ;)
    So altough it isn't safe, you shouldn't notice it that hard... But, best to leave it on, as it won't intefere with most things.
  4. friskies
    17 Nov 2003
    Ok. The firewall makes things go slower, so it got to go:) Atleast i changed the password so no one can just telnet into it
  5. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    My firewall regularly stops and reports attempted portscan attacks and such. I wouldn't ever leave it off.
    Not that I know what a portscan attack is...
  6. RTT
    RTT #parp
    12 Mar 2001
    How have you reached the conclusion that your firewall "makes things go slower"?
  7. fathom17
    fathom17 What's a Dremel?
    20 Sep 2005
    I get loads of port scan attacks on my router too. I'd never turn it off.
  8. dfhaii
    dfhaii internets
    24 Mar 2002
    Isn't it common knowledge, something to do with tubes and lorries I think.
  9. Glider
    Glider /dev/null
    2 Aug 2005
    I tought it was ships and harbors ;)
  10. ajack
    ajack rox
    17 Apr 2003
    What's your IP?
  11. friskies
    17 Nov 2003
    The thing is, when i start cs source and search for servers, i loose my internet connection if the firewall is enabled:( It can`t handle the large number of simultaneously connections.
  12. RTT
    RTT #parp
    12 Mar 2001
    What firewall are you running?
