Case Mod - In Progress ⭐ Disco Scorpion (Compaq'D)
Discussion in 'Project Logs' started by Defyant Mods, 4 Oct 2017.
  1. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    This itch is like a dose of worms :D i cant stop scratchin !!!!
    Cheers again mate :) your absolutely right no reason at all not to go with a plex chassis cept i got the itch to work with metal after seeing douglas alves's amazing 5th element build :p
    it's really just that simple.
    But ! I started a small work bench mod last week where the build is just a rgb'd plex frame :D .... and started a new tail light mod for a local subaru sti owner... so spreading my time a bit thin atm :(
    Cheers mate tyvm :)
  2. Defyant Mods
    14 Sep 2004
    Spent the day working on a new idea, still not sure if i'll go with this style of panel or maybe change it to a clear one to work better with the Tail design.
    Anyways this was just a test with some scrap 2mm white to see if the custom jig will work. Very happy with the first results and i'm sure i can clean it up better and straighter with a few more tries.
    The Jig's up! I had thought of setting up for some vacuum forming... but for a one off idea that i may not use.... it wasn't worth the time.
    The end result of the Jig is to make this!
    A fully moulded internal panel.
    The making of the jig was pretty simple and ive use threaded rod to allow me to adjust height and even angle if need be.
    Ruff cut on the saw then edges routed clean and straight. Then bolted to a base. With a centre threaded rod for alignment and tension.
    A small press plate is made. Small as all i want to be seen inside the case is the CPU water block. The Heart of Disco Scorp.
    As can be seen everything is set so the cpu will be dead centre of the case.
    Threaded bar allows for more of less height adjustmeant
    The make a panel some plex is centre hole drilled and laid onto the top of the jig. For the first test this is just a scrap piece.
    Next an outer ring is clamped to hold the plex and stop it distorting while worked.
    Heat can be applied using a hot air gun.
    Once softened the the centre press plate can be slid on and adjusted down using a nut on the threaded rod,
    I found the best way was to heat tension heat tension you can feel when to stop and add heat again.
    when at the desired height/depth allow to cool and remove the nut and press plate.
    [​IMG] \
    Pretty perfect fit for a first go,
    As you can see once fully sealed this will create a full rear chamber to duct air thru the working part of the case.
    Hopefully be sexy and functional..... and Disco!
    Still playing with lighting ideas :D
  3. _Prometheus_
    _Prometheus_ Minimodder
    2 Jul 2017
  4. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Holy moly :D I am absolutely loving this build - I've just been catching up as I've not been keeping close enough tabs on this, and I'm blown away. I normally hate RGB LEDs but this is superb stuff, and I love the work you're putting in here. The mechanical elements are super neat and unusual, and then to top it all off you're scratch building a case and deforming some plexi too?
    Bravo!
  5. Vault-Tec
    30 Aug 2015
  6. _Prometheus_
    2 Jul 2017
    hm_191650-L.jpg Excuse for it... :rock::rock::rock:
  7. kim
    kim hardware addict
    10 Jan 2016
    another great idea:clap:, the rear chamber and the way you made it out as well:rock:
  8. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    FEEL THE BASS!
  9. Defyant Mods
    14 Sep 2004
    Not forgotten just off modding a couple sets of tail and head lights :D Hope to get back into DS soon!
  10. Cheapskate
    13 May 2007
    Well, I was thinking you needed to make your own cpu block top, but that confirms it. How well does that work with the other mobo cover?
    Also: Plexi is so d*mn rubbery, you get warpage in the non-heated areas. Don't you hate that? :lol: Just do what I want, stupid plastic.
  11. Defyant Mods
    14 Sep 2004
    Cpu block was pretty much on the cards, actually looking forward to a diy block top been years since i made my last ones. Back then it was almost common place to make your own block tops. Nowadays not so much :(
    I havn't had time to try a second run on the press, wanting to try some thicker plex maybe 4mm in frost. :D That should go a long way to stop warpage.
  12. Y.G Casemod
    Y.G Casemod Extreme modder
    8 Feb 2017
    The Tron effects is fantastic.GG
