Graphics display problems
Discussion in 'Hardware' started by bagman, 7 Sep 2009.
  1. bagman
    bagman Minimodder
    18 Apr 2009
    hi guys i need your help with something (as always :rolleyes: ). i have a problem with the graphics card and the display. when i turn on my computer it starts up and i see the mobo manufactures page and then windows loads but then the screen goes blank and the monitor says "out of range" but the computer starts up as i here vista does its login noises. so what could be the problem, it is not the display as i tested the computer with a different monitor and the samething happens with that one to.
    so can you help me here as i am completely stomped by this.
    this happened after i changed my mobo
  2. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    "Out of range" means the resolution set in windows is higher than the monitor can handle.
    IE: if the resolution is set to be 1920 x 1200 but the monitor is 1440 x 900.
    This should reset itself though when the computer is turned back on.
    if you can try start in safe mode and set the resolution to the monitors native res then that should fix this.
  3. bagman
    bagman Minimodder
    18 Apr 2009
    i tryed what you sudjested slizza but to no avail as it dosen't want to apply. i got in to safe mode moved the res down to nativ res and still does same thing even though i pressed apply. the thing is nothing happens when i press apply just stays the same and goes back to the res it was on.
  4. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    that's strange.. go in safe mode and uninstall the video driver in device manager.. reboot and you should get the vga driver- then reinstall it
    bagman likes this.
  5. Slizza
    23 Apr 2009
    The good thing is we have found the problem.
    The post above by thehippoz is exactly what to do next.
    bagman likes this.
  6. bagman
    bagman Minimodder
    18 Apr 2009
    i sorted it out. thanks for the tips +rep for both of you
