News DisplayPort 1.1 approved by VESA
Discussion in 'Article Discussion' started by Tim S, 5 Apr 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    cool... it looks like an usb......
  3. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    UDI looked more impressive tbh. 10.8GBit/s hardly gives any room for increased resolution :(
  4. naokaji
    naokaji whatever
    8 Dec 2006
    will it mean the death of vga and dvi? yes and no...
    vga yes.. dvi no...
    i bet graphicscards will have one displayport 1.1 and a dvi port in the future...
  5. Firehed
    15 Feb 2004
    I don't care until there's at least four outputs per card. Seeing how monstrously huge some recent video cards have been, I don't think it's asking for that much if they'll be able to fit them.
    </display whore>
  6. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Sounds good - as long as it makes it smaller and easier to plug in and plug out.
    Dont really see the need for higher resolutions than those supported by Dual-Link DVI which this will support - but there is always someone out there who wants more.
  7. devdevil85
    devdevil85 What's a Dremel?
    29 Nov 2006
    good. any actual standard that is open and not privatized/fee-based like HDMI which will make products cheaper. Also, it's smaller than DVI and VGA. I've been waiting for this to come out for like 6 months. I read an article on it on Cnet and just thought it was a good idea put on hold... glad I was wrong.
    Question: What is the best way to get both the video an audio from the computer (assuming it has a DP1.1 port) to the Display (the Moniter/Projector/Plasma) and also to your Surround Sound System (Receiver) with only one direct path?
    My guess is that you would have to take the cable from the back of the video card to the receiver and have a DP1.1 port on the receiver (which would take care of the audio) and then from the back of the receiver to the Display. Am I right? Basically it's the same for HDMI I would expect.
  8. neocleous
    neocleous Minimodder
    12 Feb 2002
    What’s the point of another port? HDMI is the digital standard in the HD AV era and PC's are trying to integrate more in an AV setup why have such a similar yet incompatible port? Why not suck up the fees and use HDMI. Seems pointless to me.
  9. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    I agree
  10. sinizterguy
    25 Jul 2002
    Because you have to pay to have an HDMI port. For consumers to have cheaper products, a free port like the declared one is required.
  11. Veles
    Veles DUR HUR
    18 Nov 2005
    Spiffy, VGA/DVI connectors are a right ******* to use.
  12. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    Agreed, and how many time have you suddenly got a blue tint to your screen when it comes a bit loose?
    In my setup, the weight of the cables puts a great strain on the sockets on the back of my gfx card, so I would love something that would fix this (they are currently supported with electrical tape)
  13. Aankhen
    Aankhen What's a Dremel?
    15 Oct 2005
    UDI++ # 16 GBit/s, yay
  14. genesisofthesith
    genesisofthesith complete spanner
    4 Dec 2004
    Considering the low licencing costs for hdmi, manufacturers should have swallowed the nominal fees for the benefit of the consumer.
  15. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    I'm all for it, as long as bandwidth can be increased ala dual link. Not having to screw it in is a bonus, especially when reaching around behind the monitor or computer feeling your way around, then having to screw it in. DP for the win. UDI would be better, although with no support I don't think it will become widespread.
  16. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    on the monitors themselves I think that they will have more ports, not less
    probable list:
    VGA
    DVI
    DP
    Component
    HDMI
    at least we can hope that they include some sort of split-screen/switching in the panels.
    The BenQ 24" is a perfect current-day example of this
  17. GoodBytes
    20 Jan 2007
    That is why you have the screws on the plug... so that it doesn't fall out.
  18. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    Them falling out is not the problem, it's the physical weight put on the socket
  19. GoodBytes
    20 Jan 2007
    what?!, your plug has an AC adapter sort of thing?!?! Its the only thing that I can think off where it can possible brake the port.
    Look, the plug is design to hold that weight, else stop buying crazy products.
    In My opinion, it is just some crappy thing so that when you buy a new video card, and you came home, you realize that it doesn't fix because, it takes a new plug. So you change your mobo, so that means a new CPU, new RAM type, and oh look a new SATA cable, so you need to change your HDD. Moreover, the Mobo take a new power plug, so you need to change the PSU. Then guess what, the PSU doesn't fit in your case, so you need a new case, and finally when you thing you can save your IDE Optical drive.... no they decided to not have that plug anymore on the mobo... and guess what.. the only device you can plug to have an optical drive is this Blu-ray/HDDVD/DVD/CD combo reader/burner...
    In other words, you just purchased a new computer...
    Ok I TOTALLY exaggerated, but you get my point.
  20. Bluephoenix
    3 Dec 2006
    @goodbytes - not really, smart buying decisions and the fact that standards such as DVI, VGA, and DP exist ensures that such an event will not happen.
    the only way such a thing would happen is if you were using a computer made around 2001 and wanted to put an SATA HDD and a DP card in it. (the DP card wouldn't be an issue if an AGP vers is made)
Tags: Add Tags
