Scratch Build – In Progress Disruptive by elGafas [090311 UPDATE Paint]
Discussion in 'Project Logs' started by elGafas, 25 May 2011.
  1. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    Yep i have to agree. when i work with gloves i pick fingerless gloves instead. be conscious of your sense of touch to your work environment! Safety first!
  2. Tipchic
    Tipchic ***
    3 Jul 2008
    Yeah, interesting project.
    But if topic-starter lose a fingers, project will be finished.
    G-clamps will help you.
  3. elGafas
    elGafas Myopic
    2 Jul 2009
    It's really dangerous to drill through 8 thick aluminum sheets without gloves, believe me.
    I got the flu, so no updates this weekend... I'll try to continue tomorrow.
  4. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    The whole gloves argument is kind of "damned if you do, damned if you don't", though personally I'd have to agree with no gloves near spinning bits or blades! If your parts are properly clamped your fingers shouldn't need to be anywhere near.
    Either way, that aside, very interesting start I really like those little "pac-mac" brackets as you called them. Will be watching!
  5. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Love the setup for this mod! :thumb:
    Now the gloves... As big a :nono: as can be!
    Clamping is of course the best way to go, but when it's not possible...
    Aluminum get's hot, nevermind that.
    Shavings can cut you a bit, nothing that can't be sewed if worst case should happen.
    If you can't hold on to it, it'll slap you on your fingers!
    If you are REALLY unlucky and get caught, it'll break a finger!
    If that ******* catches your glove and the drill doesn't break... You are lucky to escape with a broken wrist!
    As for fingers in a too small piece in a lathe... Don't! :lol: Some might remember when I made the first res for my G5... Got my pinky caught and got the deathroll like no crocodile could have done it. It's still there, but not looking nice and it still hurts from time to time...
    I daren't even think of the consequense had I worn gloves... :worried:
  6. elGafas
    elGafas Myopic
    2 Jul 2009
    Thanks for the advice!
    Now, let's continue with the case.
    Note: All the acorn nuts are temporary, I'm gonna replace them with smaller ones.
    The_Beast likes this.
  7. Angel OD
    16 Sep 2007
    wow! This just gets better and better!
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    Yeah I'm really really liking this :clap::thumb:.
  9. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Very nice, that's some thick ass aluminum. I love it, keep it up
    :thumb:
  10. elGafas
    elGafas Myopic
    2 Jul 2009
    Thank you!
  11. elGafas
    elGafas Myopic
    2 Jul 2009
    Psu in position
  12. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    if your worried about the workpiece spinning while your using your drill press then you need to change how you drill/clamp your piece. Use a working fluid to help keep both your metal and your bit cool so they don't start fusing together, and also don't drill such long stretches at once. Do something of a pecking action, remove some material, back it off, remove some material, back it off, and allowing the chips to clear when you back off your bit should help remove heat from the cutter. Each little chip acts like a little heatsink. One piece of advice though, don't wear nylon or fleece clothing while milling metals because if the chips get hot it can melt your clothes (I have experience with this :lol:).
    Also clamping down some bracing around the edges of your workpiece just incase might be a good idea if thats possible.
    Lastly placing a thin piece of rubber between your clamp and your workpiece to increase the static friction between your workpiece and the clamp. Using a strip off an old bike tube or something would probably work just fine.
    Gloves are a serious no-no for the reasons listed above. Take the advice as you will mate, but nobody wants to see that kind of accident result from something awesome like modding.
    The case looks great so far though man! Can't wait for more progress :thumb:
  13. elGafas
    elGafas Myopic
    2 Jul 2009
  14. Droih
    Droih Your too close if you can read this
    17 May 2010
    Really getting the idea now, and I like it! :) Keep up the good work.
  15. elGafas
    elGafas Myopic
    2 Jul 2009
    Thanks!
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Sure is looking rather excellent :thumb:.
  17. voigts
    voigts New Member
    26 Apr 2006
    This looks very interesting. Nice work on the alu. I'll have to keep checking in on this.
  18. SuicideNeil
    SuicideNeil New Member
    17 Aug 2009
  19. elGafas
    elGafas Myopic
    2 Jul 2009
    Thanks!
  20. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    I like this design...but I feel like I've seen this before?
    Same concept?
