wmic can do most of it if you're not wanting to use 3rd party tools. Code: wmic diskdrives > file.txt that dumps it to a text file that you can import into excel or the like, there is a way to filter the stuff in the command line and make it more friendly and readable... but i can't remember how off the top of my head.
1) Drop to a cmd prompt and type "diskpart", then hit enter. UAC prompt will need approving 2) From the DiskPart prompt type "list disk" then enter, a list of disks should now appear. 3) Then type "select disk 0" for example, disk 0 should now be selected. 4) Finally, type "detail disk" to bring up further disk details. (Make / Model / Size / Serial etc..) To check further disks with ease, use the up arrow on your keyboard to use the previously used commands.
