Modding DIY Bobafett Fan Grill, feedback
Discussion in 'Modding' started by unknowngamer, 30 Apr 2009.
  1. unknowngamer
    unknowngamer here
    3 Apr 2009
    1st attempt.
    A bit rough around the edges, but know where and how to do better.
    the plan is to cut these out of the case itself.
    1st step, get a pumpkin lantern templet and double sided tape to the acrylic, and then cut.
    Then remove templete
    and tweak as you see fit.
    and test place over a fan.
    I've used 5 different cutting tools and experimented as I went.
    Also used 3 different types of tool to tweak.
    And tried a dremel with about 10 different types of bit.
    I've found the best combo now.
    Curved cuts best with a scroll saw with a spiral bit
    Straight cuts, use dremel wheel to get a straight narrow holw, then use a hacsaw blade held in my hand.
    To Smooth..
    For large inside edges rough sandpaper.
    For small inside edge precision needle files.
    And avoid the dremel at all costs EXCEPT for the first cut on a straight line
  2. Cheapskate
    13 May 2007
    They make some little diamond drill bits that work good with a dremel for stuff like this, (with an adjustable collet.) I also love to use an 1/8" drill bit and router cut.
    Is the pumpkin template anything like a printable adhesive backed sheet? I love that stuff.
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    Pretty damn nice!
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    nice job, shame about the crappy air flow. Ah well can't have both I guess.
  5. jhanlon303
    7 Sep 2006
    I like it. It's good and I wouldn't woory about airflow.
    john
  6. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Looks good!
