Electronics DIY Digidoc
Discussion in 'Modding' started by eaterofpies, 13 Feb 2002.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Have you tried ringing them? maybe they have compatible parts with different part #'s ?
  2. Brians256
    Brians256 What's a Dremel?
    21 Feb 2002
    Anyone know how to interface with the SMBus under Windows? Linux is awesome, but I am stuck with Windows right now (job stuff).
  3. GreatOldOne
    29 Jan 2002
    Eater,
    If you're not having any joy with those parts, try these guys:
    RS Components
    Good luck - keep us posted.
  4. specialk
    specialk What's a Dremel?
    5 Feb 2002
    I'm actually using some LM35s with ADC08831s for a little project I'm working on with a Parallax Basic Stamp II. I'm using 4 of the pairs to monitor temps around a 1990 Honda Civic Station Wagon, display them on a LCD, and then control a servo which adjusts the hot/cold control lever. :)
    -special [k]
  5. Bricolo
    Bricolo What's a Dremel?
    22 Feb 2002
    bryan-> i found this
    http://www.madhacker.org/mbmsensors.htm
    It seems that a sensor is automaticly detected on the smbus
    now, we have to learn how to control an output interface, and not an input interface like this one
  6. GreatOldOne
    29 Jan 2002
    Bricolo, (or anyone else in the know)
    That's ok for temps - what about extra fan info? Could the same circuit be modified to read the tach pulses from the fans, and then get it into MBM via the SMBus?
  7. Bricolo
    22 Feb 2002
    certainly
    but you should use another ic, this one only supports temperature readings
  8. GreatOldOne
    29 Jan 2002
    What sort?
    I'm a noobie at this, if you haven't already guessed... ;)
  9. Bricolo
    22 Feb 2002
    I'm also looking for one
    you need an ic, that monitors temperatures, but also rotation speeds of some fans
    I don't know wich one, you must search for it, and it must have a smbus interface
    the one I'm looking for must also have pwm, for being able to control the fan's speed
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Running fans with pwm usually buggers up the speed signal, it needs continuous power. You can fit an integrator ic in to convert the pwm back to linear before feeding the fan.
    Think I saw a circuit on the Micrel MIC502 pdf.
  11. Bricolo
    22 Feb 2002
    a condenser would be enouth, I think
  12. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    cant you just lob a capacitor in there to smooth the signal (as in psus)?
    69 dudes :cool:
    edit: was 69 dude for approx 1 second
  13. Bricolo
    22 Feb 2002
    yes, that's that I wanted to say
    F******g automated translator
  14. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The Winbond solution (on mobos that have fan speed control in BIOS) is a 47uF capacitor (we used to call them condensers when I was a lad ;) ) across the fan, but they run the pwm at high frequency (about 2kHz IIRC). That will give a fairly low ripple DC supply to the fan electronics, as you don't want the capacitor to fully-charge.
    It does get a bit complex with just a capacitor, as the fan needs to partly-drain it as fast as the pulse-train partly-charges it - and with a switching transistor that can pass high current pulses from a beefy psu that takes some balancing.
    The integrator circuit I've seen was nothing complex, just an op-amp IIRC.
  15. Bricolo
    22 Feb 2002
  16. cpemma
    cpemma Ecky thump
    27 Nov 2001
  17. Bricolo
    22 Feb 2002
    pics aren't expensive, are they??
  18. GreatOldOne
    29 Jan 2002
    How much are PIC's?
    This is exactly what I was looking for...
  19. cpemma
    cpemma Ecky thump
    27 Nov 2001
    PICs aren't, but the kits to write your own code to them seems to be. Maplin £100-£155? :(
  20. mcduffiem
    mcduffiem What's a Dremel?
    25 Feb 2002
    Myke Predko has a PIC tutorial book. I got mine through Amazon.
    It has a PCB for making your own "el cheapo" PIC Programmer and includes software and example code. Nick Vess has a cool Mr. Baybus project at vess.com that mentioned it.
    The book is sitting on my "to do" shelf :D, but a quick scan of it looked very interesting.
    Myke has sample chapters and other good info at his site www.myke.com.
    Cheers, Mike
