Education DIY Help: Cat Shelves
Discussion in 'General' started by Kronos, 31 Jan 2017.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    I have a mattress standing waiting council collection on Thursday which is currently in my living room which my cat Millie thinks is a fantastic place to lie and watch the world go by. So I thought I might put up a shelf for her to lie on and a a couple of others to enable her to reach it.
    Pretty much got all the components, nice bit of MDF, some carpet underlay and stuff I can use for a covering. What I don't have and the reason for the thread is brackets.
    Ideally I would like them to be hidden as in Amazon but I am concerned by A) will they hold the weight of a 5Kg cat laying on a MDF shelf around 70cm long x 28cm wide and thickness is only 18mm. The shelves to give her access (2) would not be as big of course but might need to take her weight on her way down.
    Or is there some other neat way of supporting the main shelf?
  2. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    Actually got them, but the next size up, in my basket on Amazon but I am not happy with A) the length as I would have preferred them to have gone a little deeper into the shelf and B) drilling a 14mm hole will only leave 2mm top and bottom of bracket which seems a bit less than I would be comfortable with.
  4. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    I have done a few, Using Ikea floating shelves. I have used anchor bolts that will support upto 10kg on plasterboard to be sure. and its working perfectly.
    The bolts i Got from B&Q and work like a treat.
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    As I have said I have pretty much got all I need to make these things up so not really looking to go to the expense of buying shelving. I think I have got around the lack of thickness on top and bottom of brackets by adding a layer of hardboard on the top and bottom of the MDF, gluing and stapling it which has added a bit more thickness and of course more strength. Just in the process of covering the main shelf hoping I have enough decorative upholstery nails left I bought recently for another project.
  6. B1GBUD
    29 May 2008
    Could you not get a cheap off-cut of 25mm? Wickes, B&Q or Homebase might have some going begging if you ask nicely.
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    Thought about that but as I don't have the transport and these places are all a fair bit from me it was not viable. I think the hardboard lining top and bottom should be OK.
  8. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Have you thought about a cat hammock you hang on a radiator? Our cat loves hers.
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    She is not a radiator type of cat, perhaps this is because she has a very thick coat so not keen on the beat from one. Plus the shelves are more if a height thing, well the top one anyway, as she does tend to enjoy looking down on her servants.
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    After trying to drill 3 straight holes 14mm x 165mm long in the edge of a 120mm board and failing miserably I have just bought two sheets of MDF which I will glue and screw giving me a far thicker edge to deal with. Plus I have bought myself something I have been promising myself for years a Black&Decker workbench I will hopefully make a better job of the hole drilling.
  11. Kronos
    Kronos Multimodder
    6 Nov 2009
    After a bit of a delay they are finished though as yet have not been graced by Millie.
