Modding DIY howto coat aluminium with copper???
Discussion in 'Modding' started by TTmodder, 27 Feb 2007.
  1. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    i'm wondering how it's possible to coat aluminum with copper at an diy home basis. Can someone explain to me or give me a link that descripes that???
  2. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
  3. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    Ah it was electroplating i meant. Thx spaceraver i've been used the wrong word on google to search. (D'oh)
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Short answer is no, not least because you need a cyanide-base copper plating solution, and in the UK and possibly many other places you can't buy cyanide salts without a licence.
    http://www.alu-info.dk/HTML/alulib/modul/A00354.htm
    Moved to Modding, this isn't a Guide.
  5. g0th
    g0th What's a Dremel?
    12 Apr 2005
    You can probably get away with a copper sulfate solution, but i really think you'll need to do this zinc-coating pre-treatment business properly, due to the ease with which the aluminium could be oxidised in the electroplating bath.
    Personally, i would try anodization, if you want to electrochemically finish Aluminium.
