Scratch Build – In Progress Diy-itx <---High Energy---> with Bitfenix, Dremel & AquaTuning- Nov.20.2013
Discussion in 'Project Logs' started by La carotte d l'o, 18 Oct 2013.
  1. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    Amazing handskill here ! Why I haven't a tig ?! Keep going like this
  2. La carotte d l'o
    La carotte d l'o What's a Dremel?
    27 Nov 2007
    Thanks mate! :thumb:
    Thanks. I will.. Or should i say that better is still coming. :)
    Tig sure is really usefull, and actually easy to use.
  3. keenan
    keenan Minimodder
    12 Nov 2013
    This is absolutely amazing!!! So much work and detail.. Jaw dropping to say the least!
  4. Knighthammer
    Knighthammer What's a Dremel?
    18 Feb 2011
    Pretty much have to go with Guille with that one - seriously amazing work.
    Subb'n on this project.
  5. bulldogjeff
    2 Mar 2010
    OMG this is amazing.. Really nice work
  6. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Nice work with the PSU cover. It's amazing the finish you can get with a little wet sanding. Looking great and looking forward to seeing more.
  7. Razbit
    Razbit What's a Dremel?
    17 Sep 2012
    oh man..
    This is an awesome build dude, keep it up!
    [fi] perkeleen hienoa! [/fi]
    -Another modder from Finland..
  8. La carotte d l'o
    27 Nov 2007
    Thanks keenan.
    Thanks Knight!
    Same to you too. Thank you very much!
    Yep. Shine makes things look really different.
    Its allmost impossible to imagine before its sanded.
    When i looked that psu, i noticed that i wanna polish some other things too. :)
    Thanks mate!
    [fi] Perkules tosiaan, nimittäin..[/fi]
    I noticed that you're from Turku. I actually was the last weekend in there with my wife.
    We we're looking at The Rocky Horror Show in Turun kaupunginteatteri. :thumb:
    I liked the show, and had a good time, but the trip was quite funny..
    First we left the car keys inside the locked car. Managed finally to get the doors open without breaking anything..
    Two hours after that someone smashed the back window for the car while we we're shopping.
    Irony? :D
    Some update coming later today..
  9. Hukkel
    Hukkel James' minion
    20 Dec 2012
    That PSU case is *droooooool*
    Such skill!
  10. keenan
    keenan Minimodder
    12 Nov 2013
    So much talent !! Insane..
  11. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Nice build! Like your metal work:thumb:
  12. La carotte d l'o
    27 Nov 2007
    Thanks mates!
    Thanks phinix. I have been following your latest build from Bill Owen's Facebook posts. :)
    Update
    I liked the look of the psu i somehow managed to produce..
    So i wanted to continue with the look of it, and did some chages for my plans.
    I decided to move those two 120mm Alphacool Nexxos monsta radiators in the front.
    And started to build frame for them.
    Actually i have to build a totally new frame if i wanna continue with my new idea.
    I took a little jumpstart with it.
    I did two similar parts as there is in the top of the psu, and welded them together:
    I welded sheets to the sides of the frame, and did simple cuts for them:
    Filed the cuts and did simple bendings. Now i have windows to see the radiators.
    I like to see the parts inside the case. :)
    Cut parts for the ends:
    Filed:
    Masking tape is very usefull allmost everywhere. :D
    Attached the plates:
    Before welding is important to smooth the edges, then you get smooth welds. ;) :
    Welded frame with one fan. I need to make another one, and polish the frame. :thumb:
    Should look nice in the front of the case?
    Edit: With both fans..
    Update..
    I continued with the idea of making new layout..
    So i did holders for the ssd:s, i decided not to use original hdd's at all.
    Started with cutting 3 plates and then drilled some holes.
    Bend them..
    Ssd's will be attached this way..
    Might look acceptable like this..
    But i wanted them to be thicker.
    So i cut 3 stripes to be welded to the sides of the plates..
    In this way twisted stripes can be straightened easily..
    Again.. Masking tape usually does same job as the clamps.. :thumb:
    Little hammering removes the caps.
    And corners can be easily bend with the pliers..
    Ssd tray before welding..
    And all three of them welded and sanded.
    These will be also polished to shine like the psu.
    So..
    Here's the new layout what i planned..
    Optical drive will be placed above the radiators.
    So, should i continue with the new idea, or stay in the original??
    Thanks for watching!! Tell me what you think about..
  13. Cheapskate
    13 May 2007
    -I don't know what you are up to exactly, but I'm sure it will be awesome.:D
  14. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    Holy crap! What a build! Subbed!!
    Can't wait for more updates!! *rubs hands together*
  15. myrizzle
    myrizzle What's a Dremel?
    23 Nov 2011
    Awesome build! Nice craftsmanship :)
  16. matiss
    matiss Minimodder
    24 Jun 2010
    Very nice metalworking, love it ;)
  17. Knighthammer
    18 Feb 2011
  18. La carotte d l'o
    27 Nov 2007
    Lol. :D I'll try to show it later. :thumb:
    Thanks mate!
    Thats nice to hear. Thank you!
    :lol:
    Just a tiny update..
    I wanted to make nice "tray" for the psu.
    This one will be polished too.
    First i did the bottom part. Simple cutting and couple bends..
    The faceplate to it...
    Some dremeling..
    Drilled holes...
    And filed..
    Welded it to the bottom.. And another plate too, welded them both together with one joint..
    After sanding it looks like this..
    Psu is attached to the frame with four screws from the bottom.
    Thanks for watching :clap:
    More coming sooner or later...
  19. Cheapskate
    13 May 2007
    You know the polishing is good when the part blends into it's surroundings like a predator.
  20. Mechh69
    16 Sep 2009
    Quick question why did you open up the sides of the holder for the rad? Most people buy shrouds to separate the rad from the fans so there are no dead spots. If you have different plans just disregard.
    Mechh69
