Scratch Build – In Progress DIY MDF CNC MACHINE
Discussion in 'Project Logs' started by Khalid, 17 May 2008.
  1. Khalid
    Khalid Professor
    17 May 2008
    I have made my First CNC Router complete steel in 10 days... Before making it i just studied a lot ..make the drawings in my mind and started....It was 55" x 35" and the working area is 34" x 28"....and Now i am going to make other one out of MDF and a little bigger than first one with following specifications...
    1- The size of my table is 60" x 44"
    2- The working area is 48" x 34"
    3- The travel of Z-axis is 7"
    4- Nope in this machine i am using ACME screw (5/8"-5TPI)... The length of long axis(X-axis)is 62" and the small axis(Y-axis) is 46"... the length of the z-axis ACME screw is 17"...
    5- Building material MDF
    6- NEMA 23 stepper motors 200Oz-in
    7- 36V power supply with home made SLA based controller and BOB
  2. Khalid
    Khalid Professor
    17 May 2008
    I don't know how to add pictures:(
  3. Jipa
    5 Feb 2004
  4. Attila
    Attila still thinking....
    22 Feb 2008
    And hurry up I want to see this. :D
  5. ranlai
    ranlai What's a Dremel?
    20 Oct 2007
    I am use this "http://photobucket.com/"
    To upload the photo.
    I hope this can help you~
    I want to see the "How to make the CNC Machine".
    because my CNC Machine was damaged~
  6. ranlai
    20 Oct 2007
    NEMA 23 stepper motors 200Oz-in~
    Are these stepper motors use 36V:confused:
    That must be highest speed and strongest Pull-out torque with theseself:thumb:
  7. Khalid
    Khalid Professor
    17 May 2008
    Thank You for all of ur help:)...
    Here I will use NEMA 23, 3Amp/Phase KsllingInc motors...Yup i will use them with 36V to get optimum torque and speed...Many people using NEMA 34 for their all steel construction machine, but in my case i use the same NEMA 23 200Oz-in motor with my 1st steel machine and now in the second MDF machine...
    Now in following pictures:)
    1) I need Angle iron .. Size 1 inch from this we will make slide rails
    2) Teflon/plastic ...from this we will make driving nut of ACME rod
    3) Small piece of ACME ROD about 150mm length ...from this we will make Tapping die for our teflon/plastic nut
    4) We can use steel nut, this will avoid above two stepos
    5)Skate Bearing 6201 ZZ
    6)1/2" bolts with nuts
    7) ACME RODS as i mentioned above (5/8" 5TPI) as per above mentioned length
    8) MDF 1/2"--8' x 4' one sheet
    9)MDF 4' x 8'...02 sheets
    Above are the initial requirements...not contains electronics parts
  8. ranlai
    20 Oct 2007
    :thumb:
    Well~look like so big for this cnc machine~
    Can this to cutting aluminium alloy~
    I want to change my stepper motor~
    Can something is out of topic~
    My friend in msn say~
    "Я люблю Poccию"
    But I don't know what meaning for this~
    Do you know that??
    THANKS~
  9. Khalid
    Khalid Professor
    17 May 2008
    Hmmm... Thanks God i am back..a very tedious weekend:(...
    RANLAI:) I don't know the language:( sorry... This machine i dont think can cut material..It will be huge:)
    At last, I completed my Z-axis torsion box...(My advice, always design the z-axis first and then start from there and complete the rest)http://forums.bit-tech.net/images/smilies/bit-clap.gif
    :clap:
  10. talladega
    talladega I'm Squidward
    18 Aug 2007
    this looks very nice. could you post some pics of the steel one you have made already?
    what kind of cutting tool are you going to use? a router?
    I would also like to know if this is able to cut aluminum as that would be great?
    keep it up!!
  11. ranlai
    20 Oct 2007
    :D:D
    At the beginning of I am thought that is your country language,
    Originally is Russia's language ~
    I asked a Russia's friend to tell me this sentence any meaning.:hehe::hehe:
    :eeek::eeek:
    I could not estimate its size at the beginning,
    When I saw the Z-AXIS proportion~
    This is so biggest,
    Generally speaking Z-AXIS only compared to stepper motor big one to two times~
    How about the weight with the Z-axis torsion box??
  12. Khalid
    Khalid Professor
    17 May 2008
    My steel one is able to cut aluminum, however the MDF one i don't think:( I am using the router bit set (wood working), and using only 6.7mm endmill for cutting the parts of the second machine with 100 IPM...
  13. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    nice cnc, ive alwas thought about maybe making a cnc machine
  14. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    ^^^ our school has 3 CNC mill and a CNC lathe :hehe:
    The 2 small endmills cost $12,000 and the big one cost +$20,000
    And one of our rival schools has a CNC that can cut 2 doors side by side at the same time!!!
  15. KingKinase
    KingKinase 7 1/2 " 4 T W
    8 May 2008
    Interesting work Khalid, thanks for sharing it.
    sorry for skipping a few chapters ahead, but your projects look to be coming along nicely.
  16. Khalid
    Khalid Professor
    17 May 2008
    Now ...I continue or not???:(
  17. ModimusPrime
    ModimusPrime The Dremelator
    3 Jan 2008
    I'm definately going to keep an eye on this mod. Props for going out and actually making your own CNC machine. I'd love to do something like that but my skills in this department are definately lacking.
  18. Attila
    22 Feb 2008
    Continue please Khalid. :)
  19. Xer0-
    Xer0- Waste of space
    26 Mar 2007
    Nice work so far. Can't wait to see more.
    not trying to hijack someones project,
    for anyone interested there is a set of videos on how to build a mdf cnc (different model)
    buildyourcnc.com
  20. Khalid
    Khalid Professor
    17 May 2008
    Okay here are the pics of assembling my machine:)
