Other DIY thread
Discussion in 'General' started by CrapBag, 21 Apr 2021.
  1. Goatee
    Goatee Multimodder
    19 Apr 2015
    Do you want the grain to continue to show, or a uniform even colour?
    If you want grain then Ronseal Fence Life Plus Shed is pretty nice to keep the wood grain underneath. Two coats allowing to fully dry between them.
    adidan likes this.
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Sounds like a plan, as long as it doesn't transfer when you sit on it if it's a little bit damp or something really
  3. Goatee
    Goatee Multimodder
    19 Apr 2015
    I havent sat on the fence but I dont think it would. If I wanted to make sure, a clear coat might be worth sticking over the top
    adidan likes this.
  4. adidan
    25 Mar 2009
    Hhmm, not sure if I have.
    I mean I can see the benefit but then there's also the downsides to consider.
    spolsh, Goatee and Arboreal like this.
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    I know what you mean, it should be ok but it might not be. You could put a clear coat on but it might be a waste. I’m 50/50
    adidan likes this.
  6. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
  7. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Thank you, yeh I was most pleased with that, not easy to do with a jig saw on a circular object.
    It's not perfect but about as perfect as I could get on an irregular shaped post.
  8. adidan
    25 Mar 2009
    Talking of chairs, does anybody know of anywhere you can just pick up chair frames or sites with plans for them?
    We have some old sofa cushions from, well, an old sofa and they are the comfiest leather cushions we've ever had.
    Always planned to buy or make a frame for them for a couple of window chairs.
    That plan has seen them in the loft for three years....
  9. DeanSUNIAIU
    DeanSUNIAIU Modder
    11 Aug 2021
    Diy Pete has plans you can download for just about most things.
    https://www.diypete.com/
    adidan likes this.
  10. adidan
    25 Mar 2009
    Awesome, thanks for that - I'll give it a look over :thumb:
  11. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Soooo..... dishwashers. And more specifically, their removal. When the flooring has been rather wonderfully laid right up to them and there's not enough room under the worktop to lift them up and out.
    Yes, the feet are wound fully in. No, the worktop can't be lifted. Ideally, I don't want to be cutting sections of the floor out. Looked up the manual online and it seems that to unbolt the internal metal washing area bit (which I understand is confusingly called a "tub") I need access to the sides (hidden by adjacent units) and maybe the top (hidden by the worktop). It also seems the pedestal it sits on that hides the pump etc. is one big unit, so I can't remove the front to gain that extra gap to get over the front of the flooring.
    Only thing I can come up with is angle grinding the front of the pedestal off.
    Anyone else want to have a go at suggesting an approach (nuke from orbit not an option, btw)?
  12. CrapBag
    CrapBag Multimodder
    17 Jul 2008
  13. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Remove the wall behind it & go in from the back? :rolleyes:
  14. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Would removing the feet completely (unscrewing) give you enough clearance to get it out?
  15. ModSquid
    16 Apr 2011
    No, don't think so. Screwed right in, they're flush with the bottom of the pedestal. Also not sure if I can get them completely off with the limited lift I have on the unit, but I will have a look - cheers.
    You guys go ahead and make plans for the weekend - I don't think I'll be requiring your services!
    :grin:
  16. Cheapskate
    13 May 2007
    @ModSquid - I'm not familiar with your alien tech from the UK, but most dishwashers have the back legs closer to the middle of the whole assembly. You might be able to tilt it forward enough to unscrew the back legs completely, giving you wiggle room to do the same to the front legs.
    Generally, I'm dealing with crap cabinets anyway, so my preferred option is violence.
    ed: yeah, Missed fingers' comment completely.
  17. ElThomsono
    18 Mar 2005
    Have you got a picture? It sounds like it's absolutely shoehorned in and you might have the same difficulty installing the replacement, or is it fully integrated in a weird way?
    If the flooring is laminate or the like taking it up might be the most sensible option.
  18. ModSquid
    16 Apr 2011
    Cheers all for the input so far :thumb: (not you, Ian! :hehe:).
    This is what I'm dealing with pedestal-wise from the manual, but will grab a picture once I get in:
    I don't think I can get to the back legs easily enough to remove them. Also, as the missus pointed out, the inside of that tray is, we think, a solid bottom, rather than it being a hollow frame as I first thought when I saw it.
    It certainly is right in there - we've found over the years that the previous owners may have taken some shortcuts as they went along. The floor is inch-thick proper wood, glued tongue and groove from front door across whole ground floor, through hall, kitchen and lounge to rear of house. Of course that would be the case. Hence I'm proper loathe to try any dismantling...!
    Re: the replacement, we've done cursory measuring (it's been a hall ornament for about a month now) and think it might go in. If it does, I won't have had to touch the flooring; if it doesn't (touch wood(en floor)) then I'm back to where we are now but with the choice made for me.
  19. ElThomsono
    18 Mar 2005
    Aye I'm with you, I'd say angle grinder at the standby.
    Don't want to tell you how to suck eggs but you've undone the Torx 20 screws and wound the feet as far as they'll go?
  20. DeanSUNIAIU
    DeanSUNIAIU Modder
    11 Aug 2021
    It’s roughly £60-100 a sq m to get someone to lay wooden flooring. If you can cut the cost down a bit by not doing under the units, most people will.
