Scratch Build – In Progress DM-01 Hyper Case
Discussion in 'Project Logs' started by DÈF¥âÑt¸.·´¯`¤, 14 Mar 2020.
  1. DÈF¥âÑt¸.·´¯`¤
    DÈF¥âÑt¸.·´¯`¤ Well-Known Member
    14 Sep 2004
    Trying to get my hands on a ZC-11 case as a new home for my hardware for months now has proven to be just to expensive and a logistical nightmare.
    So i've decided to just have a go and make my own. The ZC-11 is a open air case much like the Antec Torque and Cougar Conquer , even more so as it does not have any face panel at all.
    This will pretty much be an extreme budget build using left over plex spare hardware and some can spray paints for colour with a few extra ideas thrown in.
    Ive chucked in the "Hyper" Branding as i find these style cases much like Hyper Cars,
    Fantastic to look at but totally impractical as a daily driver :)
    As always it starts with some plex :) This time it's cut bent and sanded.
    This will be the Base of the case.
    Ive chucked down a few sheets of black plex to help as frosted plex on a white work bench makes for crappy pics :)
    Initially i had planned to just bend the top as well.... but the i couldn't get the sharp upper line
    So i went with a 2 section glued and reinforced section
    It's 100% important that these 2 sections are sized exact.
    The Spine or main section of the case has to have strength, So 8mm plex is used.
    This was the first one of these made. I later changed the shape to suit.
    Threaded Rod with nuts is used to attach the 3 sections.
    It's a very simple idea and with some extra bracing and end gluing it's genuinely very strong.
    The next thing to do is to add in a mother board tray.
    This will sit offset to the main spine. The great thing about this design is adjustability!
    Apart from the dress up this is really the Guts of this case.... Windows , Front and rear panels pretty much complete it, And cost wise so far it's nothing :D
    But ! Case modding is a sickness ... and i'm very very sick.... So here it comes !
    The main spine and mb tray are removed.
    First the spine.
    2 new sections of 2.5mm plex are copied and patterned. These will be hard glued to each side.
    One side will be hold the PSU and the other who knows yet :)
    These are hand sanded and hard glued to the the spine
    Next is to knock up a PSU bracket, this will be hard glued into the cut out.
    A bit of drilling and some more sanding.
    The same is done for the rear of the mb tray, This will also house the ssd's.
    Clear plastic tube is keyed with a dremel to house standard nuts and also hand sanded to cover the threaded rod.
    DIY for the outer dress lock nuts as well.
    So far so good, For a a quickie case build its working out ok.
    And of course it's ganna be "Air Cooled" !
  2. kim
    kim hardware addict
    10 Jan 2016
    always a pleasure to follow your modding threads...
  3. censored_Prometheus_
    censored_Prometheus_ New Member
    26 Mar 2019
    Wow, a fully plexiglass case? :jawdrop: Unexpectedly. :rock::dremel:
  4. pccustom
    pccustom Active Member
    12 Jul 2017
    very interesting good job..
  5. censored_Prometheus_
    26 Mar 2019
    Always jealous of people who can embody their beautiful idea in the material. :lol:
  6. Cheapskate
    13 May 2007
    HA! HA! Nut Covers!
    It's good to see you back at it. :D
  7. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Nut's cover is the definition of "Attention to detail" :rock:
  8. Cheapskate
    13 May 2007
    I don't cover my nuts, I embraced them in all their glory, and gave them a good rub -er.. polish.
  9. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    :thumb:
    I forgot how much i miss the banter :grin: :rock:
    I spent way too much time making some more ...but i'm thinking only 2 maybe 4 more to go :dremel: But i thought i'd see if i could change your mind Cheaps :)
    I made an extra 2 just for you ! i hope the size is right :grin: :lol:
    The GPU bracket is done :)
    I like that thanks to the threaded bar i should be able to adjust the card away from the side as needed.
  10. MLyons
    MLyons Half dev, Half doge. Staff Administrator Super Moderator Moderator
    3 Mar 2017
    Another post from the acrylic whisperer. Just what I need to get me through these dark times.
  11. pccustom
    12 Jul 2017
    really really an amazing job!!
  12. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    Very nice indeed
  13. Cheapskate
    13 May 2007
    You cheeky sh*t... :lol:
  14. abbas-it
    1 Jun 2011
    @ cheap. Whaaat. I really meant that. Honestly.
  15. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Cheers ML Your doin great mate :thumb:
    Thanks mate :D and ty for the inspiration :rock:
    Cheers mate always great to hear from one of the gods of modding :dremel:
    Thought you'd like that :naughty:
    LOL that's not for you , read my last post :p
    MLyons likes this.
  16. Cheapskate
    13 May 2007
    He was probably what-ing the entire conversation.
    I had a problem with nested nuts, (oh, dear...) in 'Toad. They would break loose from the glue when tightened. I assume you are using something silicone-based instead.
  17. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    They should be alright Cheaps , they don't pop when tightened cause there's no pressure thy'r just caps :thumb:
    Not a hug update, just worked on making more tubes and a few finishing off touches.
    I'm using these cool little clear perspex screw to mount the SSD's on the back of the MB tray.
    It's a bit of a pain if i wanna change a ssd down the track but for the sake of a clean back panel i'm willing to take the trade off.
    Finished off the the GPU bracket with a panel to hide the riser cable, will also work as a card support.
    Last but not least ive added some pattern panel to the inside floor,
  18. BigShadow
    BigShadow New Member
    10 Feb 2020
    Looks awesome!!
  19. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    Small update till the weekend, then a lotta sanding and prep work hopefully for some paint.
    Added a cut out panel for the top and did some front panel work.
  20. DÈF¥âÑt¸.·´¯`¤
    14 Sep 2004
    This is pretty much how the bulk of the next few posts is going to look, just a whole lotta sanding , primer, high filler and more sanding.
    Only a couple of hours into it and i know i'm in for the long haul..... actually taking me back to the good o'l Bondo days of HP-1,2,3,4,5 AND 6!!!!!
    Cause i'm making this from heat bent plex and bent plex warps. It's going to take a bucket load of work to make this top section look pro.
    As seen in the above post the front looks pretty ruff. The tabs sections that drop down the sides are only there for bracing while i sand and will be cut away... but for now they stop the sides from flexing in.
    I'll smash the bulk of the work with some 120 grit dry them move up to some 600 then over to 400 wet and dry and so on.
    To make sure it's 100% flat im using an extreme large block and just like the old days i'll work to my edge not over and around them!
    This cuts one clean flat surface at the exact angle.
    The side due to the massive warping will take a lot lot more. But as you can see the large block is already cutting a nice lines.
    To help see the line better i add some primer paint, this also shows the lows as the sand paper misses these spots.
    censored_Prometheus_ likes this.
