Windows DNS Lookup
Discussion in 'Software' started by PaulJG, 17 Dec 2013.
  1. PaulJG
    PaulJG Minimodder
    20 Mar 2009
    Would you guys be able to give me some advice please..
    I've got the new fibre sky hub.. which as you can imagine is locked down to stop you getting to all the good settings. What I want to do is use OpenDNS, not sky's..
    Now without having to buy a new fibre modem/router and do a few tricks to get at the password/username - I want to try to get on with theirs for a while.
    I've put the opendns settings into internet explorer - even tho the router is using the default sky settings. Soooo question is.. is it using those settings (ipconfig shows it is) - but is it??
    Or is it still going through the sky dns to get to the opendns servers??
    Is there a way I can trace the route???
    Thankyou for your time.
  2. workingclass
    workingclass What's a Dremel?
    17 May 2010
    Sky might be locking websites based on IP addresses, in which case it doesn't matter which DNS you use. Not sure if this is the case or not though.
    In Denmark a few years ago I had set my dns to opendns before they started blocking access to file sharing websites and everything just worked for me. Then one time I lost connection to their network, and nothing worked until I set the DNS to auto, and after that, no matter what dns I used, nothing worked. I'm sure there were ways around that but it wasn't a pressing matter at the time, and I didn't understand networking then like I do now.
    What I'm saying is, you might need to do more then just change DNS, and google should have that information.
  3. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    you can trace the route you are using to get to certain websites in cmd prompt by typing tracert {website} ignore the brackets just type the website address ie tracert google.com
  4. Krazeh
    Krazeh Minimodder
    12 Aug 2003
    If you want to know if you're using the opendns servers goto the cmd prompt and type 'nslookup'. It should show you the address of the dns server being used for lookups.
    Sent from my Lumia 925 using Tapatalk
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
  6. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
    DynDNS is usually more for when you don't have a static IP and want to get back to your router from the outside world using a hostname. Useful if you are hosting behind a dynamic IP address.
    As Krazeh says, nslookup should show you what DNS server you are using for your lookups.
  7. RichCreedy
    24 Apr 2009
    when I use nslookup, it tells me i'm using 192.168.1.2 ;-)
    ok ok I admit it i'm on a domain
  8. PaulJG
    PaulJG Minimodder
    20 Mar 2009
    Thankyou guys for the help and advice..
    I did a nslookup - came back: resolver1.opendns.com - address 208.67.222.222
    Which I believe is the Opendns, so thats all good! :) Must be bypassing the routers DNS settings.
