Displays Do I have to get 3D vision monitor for Nvidia 3D vision?
Discussion in 'Hardware' started by SoloC350, 23 Jul 2012.
  1. SoloC350
    SoloC350 What's a Dremel?
    16 Jul 2012
    Hello. Yesterday I just discovered that my Geforce GTX560 TI has a 3D vision ability so I checked in my driver and find the 3D section. When I finish the 3D test that confirmed that I can see stuff in 3D I just launch my Battlefield 3 and played in 3D. It seems like I need a two blue glasses because there was to much red in the 3D vision so I jumped over to nvidia website and saw their glasses. Apparently, for the 3D vision, I need a 3D monitor and their 3D glasses. I don't have a problem to buy the glasses but buying a new monitor is to expensive specially after I upgraded to the Dell U2312 last month. The question is- do I really have to get one of their 3D fancy monitors?
  2. chrismarkham1982
    chrismarkham1982 Multimodder
    1 Apr 2010
    Cant quite remember how it works but I think you need a 120hz monitor?
  3. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    The real question is do you really need 3D? I have seen movies in the 3D though never played and games. My GPU supports 3D but on the whole it will put a strain on performance!
  4. chrismarkham1982
    1 Apr 2010
    The above is true, 3d does put quite a hit on FPS
  5. Guest-16
    Guest-16 Guest
    Do you need a 3D Vision monitor for Nvidia 3D - short answer is yes. They are qualified to work together as Nvidia does a branding program.
  6. SoloC350
    16 Jul 2012
    Thanks!
  7. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    This. However, if you're doing it the old red and blue way, as far as I'm aware any monitor will do as it displays both images at the same time with the glasses doing the filtering.
    David likes this.
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    You need the 120Hz so that it can display both images at once, each of those frames being at 60Hz. one "red" frame at 60Hz while displaying a "blue" frame also at 60Hz both at the same time, which = 120Hz.
  9. SoloC350
    16 Jul 2012
    Thanks!
