Graphics Do I need a 5850?
Discussion in 'Hardware' started by ahodder, 3 Jun 2010.
  1. ahodder
    ahodder What's a Dremel?
    21 May 2010
    Hi,
    I mainly use my pc for design work and CAD rendering with a healthy splash of gaming on the side. But the games I play tend to be fairly old and not cutting edge!
    I've recently built a new pc but held out on a graphics card to wait for the 5850 to drop in price.
    Do I need a 5850 or should I go for the much cheaper 5770.
    I use Autodesk Showcase for my renders, requirements here.
    Thanks
  2. murraynt
    murraynt Modder
    6 Jun 2009
    580 it is deferentially more future proof and will speed up rendering even more.so if you intend in keeping the system and can afford it go for the 5850
  3. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    What screen resolution do you use? Can you tell us anything more about your system - CPU etc?
    There's slightly different answers depending on other components. I suspect a 5770 will be OK for you however.
  4. murraynt
    murraynt Modder
    6 Jun 2009
    I agree.Although for rendering it would be brilliantly quick, especially if the pc is used for work
  5. rollo
    rollo Modder
    16 May 2008
    5770 is overkill for rendering
    5850 is even more overkill
    4890 260 or 5830 would suffice up to 1920x 1080 without issues
    5770 below that rez is fine.
    5850 is pretty poor if you can get the 260 in sli on your board it will destroy it and its about £60 less. or 4890 for that matter.
    4870/50 in crossfire delivers epic level of performance and is less than £200 its faster than the 5850 as well ( friend of mine picked up 2 4870s for around £120)
    a cheap 4850 or 4870 would do the job if games arnt a major concern;
    depends on budget to what you get. These days 5830 and 5850 are struggling to hold there own due to massive price increases.
    5830 is around £160 (http://www.overclockers.co.uk/showproduct.php?prodid=GX-238-SP&groupid=701&catid=56&subcat=1711) the avr 5850 (http://www.overclockers.co.uk/showproduct.php?prodid=GX-004-HS&groupid=701&catid=56&subcat=411) is £230 + more if you want a decent cooler.
    and the 5850 is not £70 better than the 5830
    once the 5830 breaks the £150 barrier it makes the 5850 look even worse.
  6. murraynt
    murraynt Modder
    6 Jun 2009
    sorry you make a good point.although i think the 5850 is worth the extra money over 5830
  7. ahodder
    21 May 2010
    Thanks so far
    Hi and thanks for the advice so far.
    Additional details about pc spec:
    17-920
    Gigabyte X58-UD3R
    6GB DDR3 1600
    1TB F3 Spinpoint
    700W modular power supply
    EDIT: Current resolution is 2 screens at 1920 x 1080. Thanks
    Graphics card is currently a Nvidia Gtx210 that I got for about £30 to tide me over. I'll sell it on when my new card/s come.
    I have never played with sli/cross-fire before and so do not really know how to set that up. If it's easy then I' be willing to give it a go.
  8. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
    if you can afford the 5850 you should get it, future proof and the 5830 is not much cheaper tbh
