Electronics Do I need an inverter?
Discussion in 'Modding' started by Kronos, 10 Jul 2014.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I'm pretty sure you should just be able to wire it to the yellow wire and one of the black in a molex connector, as it says they are 12V so that should be fine.
  3. Beasteh
    Beasteh What's a Dremel?
    18 Feb 2012
    Looks like you don't need any special electronics for this one. Just connect it up to the 12V and ground wires on a molex connector.
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    Thank you both. I suspected as much.
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    Normal LEDs don't need an inverter as they run with standard 12 DC power that the computer PSU provides.
    Cold cathodes on the other hand require an inverter because the tube needs a much higher voltage than the PSU provides.
  6. Margo Baggins
    28 May 2010
    That's fairly misleading as there isn't really any such thing as a "normal" LED...
    Lots of different LED require lots of different forward voltages. most of the LEDs that I use tend to run from about 2 - 3.5v @ 20ma. I wouldn't be surprised if those strips had resistors to bring the voltage down to something similar and are infact 12v due to them being intended for car installations etc. and being run off the 12v supply.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    I'd mis-edited 12v out of the sentence, it should have read:
    "standard DC power that the computer PSU provides."
