Linux Do I need any antivirus software on Ubuntu?
Discussion in 'Software' started by mm vr, 18 Dec 2007.
  1. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I'm installing Xubuntu or Fluxbuntu (haven't decided yet) on an old computer (you can discuss and suggest hia).
    So, just a simple question, is antivirus software needed or recommended on Ubuntu?
    Also, if someone has a good suggestion of a free and lightweight antivirus thing for Win98SE, could you please share it with me?
    Thanks in advance! :thumb:
  2. rito
    rito What's a Dremel?
    19 Sep 2007
    no, you probably won't need antivirus stuff.
  3. Glider
    Glider /dev/null
    2 Aug 2005
    If you don't constantly log on as root, chances are slim that you'll get virii that cause any damage.
    What you will get is a good laugh when poorly made sites claim your C drive is infected... :D
  4. Jipa
    5 Feb 2004
    I suppose you'd get more responses by mainly asking for a light antivir for 98SE.. Because unline Ubuntu it really needs one! AFAIK you don't need antivir with any unix-based OS as there's no viruses for those either. One of the things that make them perfect... According to some :wallbash:
  5. BlueTrin
    BlueTrin What's a Dremel?
    15 Dec 2007
    Get the habit to restrict the rights of your main user
    and use sudo !!!
  6. mm vr
    18 Nov 2007
    Thx for the fast responses.
    Gr8 that I don't need any antivirus on Ubuntu.
    Actually, I read somewhere that a guy was surfing, then a popup window opened and it downloaded an exe file on the desktop... Luckily he was on his Linux... lol :D
    If you have any knowledge or just time please take the time answer to the other thread too, can be found here.
  7. BlueTrin
    15 Dec 2007
    Heh if you want safe surfing on windows, I highly recomment you noscript plugin for firefox ... it is a hassle at the beginning to manually allow the websites where scripting is allowed but since you usually navigate the same pages and since it takes two clicks to allow a website, it is a quite useful addin.
  8. mm vr
    18 Nov 2007
    WOW that's cool, please tell me where to get that plugin! (Do I need any additional antivirus when using that plugin BTW?)
  9. Jipa
    5 Feb 2004
  10. Glider
    Glider /dev/null
    2 Aug 2005
    Noscript does nothing to stop idiots from pulling in Virii tough... Noscript just refuses sites to run any scripts (thus avoiding them to install stuff)
    And OT, there ARE viruses for Linux/Unix, don't be mistaken... They just aren't common and require fools to get installed.
  11. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    on a different note i prefer having a linux antivirus to scan the windows partition, but thats personal preference
  12. Tsen
    Tsen Steeped In Romance
    29 Apr 2006
    As far as I know, there are no virus scanners available from Linux apart from scanners designed to check on hosted Windows computers or partitions. Virus-wise, you shouldn't need any protection, but Linux can still be hacked, so use a firewall and don't run as root, use sudo instead.
  13. Glider
    Glider /dev/null
    2 Aug 2005
    ClamAV is a Unix antivir (mostly used on mailservers). You could probably use it to scan your windows partition too.
  14. mm vr
    18 Nov 2007
    Thanks for the suggestions, I'm propably not going to use any antivirus, but as you guys suggested, propably Noscript and running as a non-root will do it. Do you have any Linux firewall suggestions?
  15. Glider
    Glider /dev/null
    2 Aug 2005
    Iptables?
  16. mm vr
    18 Nov 2007
    Is Iptables a firewall? Please provide me a link.
    EDIT: Nevermind the link. Found info of it from Linux wiki. Seems pretty difficult to use, but I think everything on Linux is a bit difficult for the first user...
  17. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Firststarter (?) is a good front end for iptables, nice and easy to configure until you get the hang of setting your own rules
  18. Glider
    Glider /dev/null
    2 Aug 2005
    IPTables seems hard at first, but once you get what chains are, you're set ;) Just read up on some guides and you'll be fine ;)
  19. mm vr
    18 Nov 2007
    OK, will be then using Iptables!
    Learning to use isn't that hard then, well.
  20. Tsen
    29 Apr 2006
    Firestarter's decent, but it's better to just learn to use iptables in my opinion.
