Graphics do i need to have catalyst control centre open for...
Discussion in 'Hardware' started by j4mi3, 3 Mar 2012.
  1. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    it to apply my overdrive overclock?
  2. j4mi3
    28 Jun 2011
    and by open, i mean the program actually started and in the tray,
    because i have set it to not start on startup i was wondering if my oc is still being applied
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I would assume you need it at least open down in the tray. Run GPUZ to see what speed your card is running at if you want to know for sure.
  4. j4mi3
    28 Jun 2011
    yep you were right. gpu-z reports it at stock until i open it. cheers
