do these things work?
Discussion in 'Hardware' started by isho, 8 Sep 2007.
  1. isho
    isho What's a Dremel?
    10 Jun 2004
  2. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I don't see why not, but I can't imagine what I'd use one for now. Back in the PS2 days, I often fantasized about monitor/TV convertors, to run consoles on CRT monitors, but with HD tvs the whole biz is rendered moot (no pun intended).
  3. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    I'd be more confident about it working to display a VGA signal on a TV than the other way around.
  4. isho
    10 Jun 2004
    well im not getting an HD till black friday. i should be able to get one cheap.
  5. crazybob
    21 Oct 2004
    That little converter won't do you any good at all for an HDTV, if that's what you were thinking. The converter you linked will only work for standard definition. If you want to display HD from your computer, you need one of three things:
    1) A TV with DVI or VGA in. This is actually pretty easy to find.
    2) A video card with component video or HDMI out. This is also pretty easy to find.
    3) One of these two converters: http://www.newegg.com/Product/Product.aspx?Item=N82E16812203023 or http://www.newegg.com/Product/Product.aspx?Item=N82E16882125103
  6. isho
    10 Jun 2004
    oh i know, right now i only have a standard def tv.
  7. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    It'll work but the picture will probably look like ****.
  8. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Read the auction:
  9. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    I had SVGA 2 Scart by keene but it didn't work with my 19" lcd and i haven't found anything else.
  10. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    You're gonna have a bit of a wait then, 'coz there isn't another "Black Friday" this year :idea:
  11. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    I think things might be different in the UK, at least here in the US, Black Friday is the huge sales and shopping day the Friday after Thanksgiving.
