Do you save the box?
Discussion in 'General' started by cpemma, 8 Jul 2007.
How long do you keep the packaging?
  1. Ripped to shreds in my rush to get at the goodies
    1 vote(s)
    1.1%
  2. Check for faults and out goes the box
    13 vote(s)
    13.7%
  3. Sent off round the ebayed old item
    4 vote(s)
    4.2%
  4. Till the warranty expires
    33 vote(s)
    34.7%
  5. The box has turned into compost in the garage
    44 vote(s)
    46.3%
  1. cpemma
    cpemma Ecky thump
    27 Nov 2001
    How long do you keep the packaging that comes round that new piece of AV or PC equipment? Just long enough to check it works, or long after the warranty has expired?
    I seem to have a roomful, often with the old equipment stuffed inside just in case the new one breaks. Guess I'm a hoarder. :blush:
  2. atanum141
    22 Jul 2004
    usually a year or so.
  3. DougEdey
    5 Jul 2005
    I normally keep it for about 18months tops as I tend to sell if after. But sometimes during my constant state of movement it gets ravaged
  4. Veles
    Veles DUR HUR
    18 Nov 2005
    Usually keep mine for as long as I keep the product, especially for stuff like mobos since it still has a load of the goodies still in the box.
  5. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    way to long...
    I have lots of boxes filling up the basement. I'm not quite sure why i keep them, though...
    it's a bad habit, i know.
  6. dom_
    dom_ --->
    4 Jan 2004
    Depends, pc stuff i bin it straight away.
    Hi-fi stuff i always keep the box and packaging as it adds value to the re-sale.
  7. RTT
    RTT #parp
    12 Mar 2001
    Depends on the value and what it is really. I mostly keep boxes for added resale value
  8. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    Where's the option for 'flattened and filed away in the appropriate location in my "box cupboard"'?
  9. ChriX
    ChriX ^
    30 Aug 2001
    Same. Although, I still have all the huge boxes from the last complete PC setup I bought in 1996. The PC is long gone :D
  10. samkiller42
    25 Apr 2006
    I keep boxes for every product i own, unless its something like headphones for my Zen, or my Power Tower, but im one of those who keeps everything for anything:D
    Sam
  11. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Same for me here. I have a big pile of boxes of all kind of crap:D
  12. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    Big things liek graphics cards, cpus and motherboards i keep the boxed for, lots of them shoved into the box for the case they went into :lol: but things like fans i dont bother with.
  13. ComputerKing
    8 Sep 2006
    Till I throw the hardware I throw the box with it :D
  14. Zurechial
    Zurechial Elitist
    21 Mar 2007
    I keep all boxes from expensive items, and also boxes that can be useful for storage.
    I find motherboard boxes are great for storing the random junk supplied with hardware 9screws, IDE cables, backplane covers, etc).
    Warranty-paranoia is also part of my reasoning. :p
  15. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    I keep boxes, but they usually don't last that long as they always get used to store something else.
  16. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    I've still got the box for almost everything I have bought (over £100) in the last couple of years. The only exception is my macbook pro's box which is in landfill in San Francisco somewhere.
  17. Sp!
    Sp! Minimodder
    6 Dec 2002
    I have a loft full of boxes for stuff some of which I'm sure I don't own anymore, occasionally when I go up there I chuck a couple of older ones away.. but mostly I just like to hoard stuff...
  18. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Usually till the warranty goes. Then they get binned.
  19. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    As long as I keep the item/warranty, it's really dependant on the item, some stuff I just ditch outright, things like packaging for cables or heatsinks.
  20. Guest-23315
    Guest-23315 Guest
    I keep all of the boxes for most stuff over about £20 or so in a big plastic box in the attic.
