http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3407086520&category=3670 (This auction is not mine.) Do you think I should trust it? I mean, Antec uses this as their 550W True Power. Should I trust it on how the inside components are made by CWT? The ratings are the same.
I figured out the shipping for an Antec Truepower that weighs five pounds and the shipping is basically the same as it is for this power supply.
I think I found the real manufacturer of this one - http://www.openlinx.com/english/product/product_description.asp?product_id=1015 I don't know if they use CWT parts or not. It seems they do because of the ratings.
Probably doesn't have them knowing that the fans are changed. It has an 80mm on the bottom rather than a 92mm. Plus, the casing for it is different.
