Graphics Dodgy PSU or Dodgy GFX Card
Discussion in 'Tech Support' started by WarrenJ, 10 Dec 2018.
  1. WarrenJ
    WarrenJ Well-Known Member
    14 Oct 2009
    So after turning my PC on this morning. Working on it for approximately 30 minutes the machine suddenly switches itself off.
    Here's the spec.
    Core i7 8700k (OC)
    16GB Ram
    650w PSU
    Zotax 1060 6GB AMP!
    Asus Z390-F
    Initially as soon as the computer was switched on there was a click and everything turns off.
    Disconnecting the motherboard and using a jumper to turn the PSU on, the same symptoms.
    Disconnecting the GFX card from the PSU and all the lights come back on.
    After replacing the GFX Card with an old GTX750Ti (no additional power requirements) the machine boots up, however I am left with a conundrum.
    Would you say a part of the PSU popped supplying the GPU or the GPU is dead?
    I have another machine I should be able to test it in later (once I have a hdd) to find out for sure.
  2. WarrenJ
    14 Oct 2009
    Okay. little update.
    My god, burning electronics smell sooo bad.
    Plugged into my other PC. Same issues, only problem this time, there's a small pop, some smoke and a tiny bonfire inside the case. Yup, GPU is fried. No idea why. I was playing CSGO on it last night without any issues.
  3. WarrenJ
    14 Oct 2009
  4. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Yep, that's toast(ed).
  5. ferret141
    ferret141 Well-Known Member
    18 Oct 2010
  6. WarrenJ
    14 Oct 2009
    Canon 6D with 100mm Macro 2.8
  7. ferret141
    18 Oct 2010
    Looks better than a microscope
