Displays Does 1080p/i HD downscale to 1050 or similar?
Discussion in 'Hardware' started by Tomm, 16 Jul 2007.
  1. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    I'm confused by this HD business (Isn't everyone?). I'm looking at buying a 20/21/22" monitor (I.e. 1680 x 1050) and I understand that this is NOT fully HD compliant, because it can't manage 1080p/i, only 720p. So if you buy a blu-ray/HD-DVD movie, can it play as both 1080 or 720?
    My current 17" CRT still manages 720p (1280 x 720), though. So if I was to play 1080 content on my new monitor, would it downscale nicely to fit the screen, or would it revert to a 720 version and upscale that?
    I think that makes sense. Kind of.
  2. lamboman
    lamboman New Member
    25 Jul 2006
    Well, in general, downscaling works on ratios. So, I would find out whther they are equal ratios , which will give you the answer.
  3. Amon
    Amon inch-perfect
    1 Jun 2007
    It will be perfectly fine as the movie will just interpolate down to match the display, but your video card will have a very difficult time decoding movies at a 1080 signal, causing audio/video synchronization issues, very long command latencies (pause won't pause for at least 5 seconds), inconsistent video/audio track playback, and so on. Now, I am not completely sure, but the playback performance on your computer will probably a bit unsatisfactory.
    BTW, although you're close, my computer is still the very worse computer we have at Bit-tech... ;)
  4. Tomm
    12 Apr 2004
    Pfft, what you talking about? I'm rocking a gig of RAM to your two, and a 3200+ to your 4000+. I don't really care though, this computer is still as zippy as it ever was, and I don't need anything more for what I do (The hardest workout this computer gets it CS: Source). To be honest, I can't see myself getting into the HD business any time soon, but I figure a decent screen will outlive this computer anyway, so I want to make sure it's 'future proof' as much as possible.
    Anyway, back on topic, what do you mean by interpolate down? You mean a 720 video will upscale to match the res of my screen? Or that 1080 will downscale (which would be what I want).
  5. Amon
    Amon inch-perfect
    1 Jun 2007
    Yes, 720 will upscale and 1080 will downscale slightly to fit. It will be fine and you won't experience any poor interpolation (i.e.: nothing less than bicubic interpolation.) However, depending on how well your video card can decode such a wide signal (probably not good at all), you might run into a few hiccups during playback or when trying to fast-forward/rewind, etc.
    P.S.: my 9600 SE is the very worst D3D9-compatible video card in existence. Sh*t. It's less powerful than a Radeon 8500 and really craps out my system, which is otherwise exceptionally fast (kind of) for the degree of megatasking I do.
    A not-too-distantly-representative example
    . Some days, I'd need to triple-stack the taskbar to cope with the open apps.
  6. DarkOne42
    DarkOne42 How many PC's do you have?
    18 Jul 2007
    You will not have any problems upscaling or downscaling sources. I currently run a media PC on a 1080p TV, however due to a firmware fault on the TV I have to drop the resolution a bit to 1010 lines to fit on the TV (Another story). Anyway, I use a MSI 7300GS card with HDMI and a E6300 processor with laptop hard drive and can play HD 1080p/720p movies with no problem. No pausing or noticable resolution issues)
    When using my 1050line monitor, again I can not see any resoltion issues.
  7. Krikkit
    21 Jan 2003
    The newer cards in the world have specialist featuresets to enable faster downscaling/upscaling of HD content DarkOne - the 9800 doesn't have this because it's too old.
  8. Tomm
    12 Apr 2004
    Excellent, I think that's cleared things up. Thanks everyone.
