Cases Does anyone have the Enthoo Luxe?
Discussion in 'Hardware' started by pete*, 2 Apr 2016.
  1. pete*
    pete* Something witty here.
    29 Apr 2009
    Hi all,
    I'm looking to buy the Enthoo luxe, but I'll be having two SSD's in it hopefully mounted behind the
    motherboard tray.
    However reviews I've read say it comes with only one of the brackets to hold it there, while
    a couple have said you get two with the case.
    I was wondering if anyone has one and could confirm, and also if you think the double SSD bracket
    phanteks do (same bracket but holds two SSD stacked) would fit in there?
    Thanks in advance for any help,
    Pete
  2. David
    7 Apr 2009
    Bit-tech's review suggests that it comes with two SSD mounts behind the mobo tray, and that they also accept Phanteks' own double drive mounts.
  3. pete*
    29 Apr 2009
    Actually can't believe I missed that. I am so dumb.
    Cheers
