Motors Does anyone know about OBDII scanners?
Discussion in 'General' started by GreatOldOne, 3 Jul 2011.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Guys,
    I'm planning on doing a lot more servicing and work on my cars in the future, and I'm sure that an OBD2 scanner will come in handy.
    The thing is, there so many of them. I've been reading up, and I've just got myself more confused over what I need.
    Whatever I get needs to work on the Jag (S-Type Diesel) and the Golf (Mk5 Diesel). I don't expect it to work with the Gooster, as it's an old, pre OBD BMW interface.
    Can someone advise? I know that there are specific VAG units, but then a lot of them seem to indicate that they'll do all cars...
    I think I'd like a standalone unit - not a PC based one (Mainly as it'a going to live in the garage, and also due to the fact that I run Macs).
    Here's what I think may be a candidate:
    http://www.ebay.co.uk/itm/Autel-MS5...2588179287706247&_qi=RTM742988#ht_5218wt_1165
    Ta
    GOO
  2. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    Hi GOO
    for the Mk5 diesel golf - same i have- i would recommend nothing other than a vagcom cable. its effectively dealer level stuff, you can clear codes across ALL the controllers within the car along with playing around with some of the settings to enable extra 'hidden' features etc etc
    I didnt pay for the ross-tech one, however, the one i bought off ebay for £24 has thus far not missed a beat and indeed it does do ordinary OBD scanning too.
    I'm not sure whether jaguar have their own protocol like vag do, or if you just want an obd scanner for the jag, in which case get the chinese vag com!
    it does mean its tied to a PC however, its fully worth it.
    http://www.aliexpress.com/product-f...vag-com-vagcom-SUPER-QUALITY-wholesalers.html
    thats the exact one. pay with paypal after selecting UK as shipping destination and enjoy!
  3. GreatOldOne
    29 Jan 2002
    Thanks - but I do want a stand alone one.
    Anybody else?
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I thought the idea behind OBDII was for all brands to use the same protocol. (For reading data, that is). If you want to write, then every brand is different, yes.
    And I do believe that you could read the memory from the gooster. You will need an adapter, as the earlier BMW engines (Up to 2001, i think) had a different connector (Large round one with a screw-on cap)
  5. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    Should you happen to own an Android handset there is an app called torque that should allow you to read the error codes, if you have a Bluetooth model? Not sure if that is any help to you or not? I am toying with the idea of getting one myself, but I think my Pug is a bit too old.
  6. GreatOldOne
    29 Jan 2002
    I just found this in my googling:
    http://www.yhasi.com/index.html
    Native OSX OBD software. Which looks pretty nifty - but I wonder if I want my mac to get all oily. ;)
  7. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    I have the cheaper version of the Autel in your link. It will clear fault codes and show current readings etc from the ECU.
    To work on diesels they need to be 2004 onwards though.
    VAG-COM is definitely the ultimate when you have a VW, the amount you can do with it is unreal.
  8. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    It will come in handy, about once every blue moon depending on the quality and age of your car.
    I'd love one as I have always done 100% of my own servicing and repair work on all of my cars & bikes, but I've only ever 'needed' one once in nearly 20 years and in that instance a paperclip showed me ehat I needed to know
  9. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    i have THIS. its not expensive or fancy, but it allows you to read and clear codes and monitor supported OBDII compatible PIDS (so no body/ABS/SRS related data). we have a $6,000 Verus at the shop i work at and i find myself using my simple little Launch more often than the Verus.
