(Does not support this Operating Sytem: WNT_10.0P_64)
Discussion in 'Software' started by kuroidoragon, 7 Aug 2019.
  1. kuroidoragon
    kuroidoragon Minimodder
    14 Oct 2012
    I have a Asus TUF Z370 Pro-Gaming motherboard on Windows 10
    when I try to install the latest version of my drivers for the various features & components etc
    it keeps telling me (Does not support this Operating Sytem: WNT_10.0P_64)
    How do I fix this & get the latest drivers installed ?
    I have tried googling it & found nothing usefull yet
  2. RedFlames
    23 Apr 2009
    Which drivers? Also are the off the disk that came with the board or the ones off ASUS' site [or direct from intel or wherever]
    kuroidoragon likes this.
  3. kuroidoragon
    14 Oct 2012
  4. Gareth Halfacree
    4 Dec 2007
    First: double-check that you downloaded the Windows 10 64-bit versions of the drivers, rather than the Windows 10 32-bit versions.
    Second: check that your drives are set to AHCI and not IDE in the BIOS. I don't know why that breaks Asus' installers, but it does.
    Thirdly: if the drivers you've downloaded have an asussetup.exe and a setup.exe, run setup.exe and ignore asussetup.exe.
  5. RedFlames
    23 Apr 2009
    I meant is it a specific driver that you're having problems with - chipset, audio, or are you having problem with all of them.
    EDIT: Also, what @Gareth Halfacree said plus:
    Fourthly: Try the intel drivers from intel themselves.
  6. kuroidoragon
    14 Oct 2012
    Yes they are the windows 10 64 bit versions
    How do I check if my drives are to AHCI & not IDE ?
    I have tried both setup.exe & asassetup exes niether work
    I have a quick flick through to see which ones do the message described in original post above
    I am having problems with
    Lan Drivers
    Sound Drivers
    VGA Drivers even though no one uses them I checked anyway
    How & where do I get them from intel ?
  7. RedFlames
    23 Apr 2009
    if you're not sure what to look for on the intel site -
    Ethernet driver - https://downloadcenter.intel.com/do...k-Adapter-Driver-for-Windows-10?product=36773
    Chipset - https://downloadcenter.intel.com/download/28182/Chipset-INF-Utility?product=125903
    You'll only need the GPU divers if you're using the integrated GPU, but if you are then they're here - https://downloadcenter.intel.com/download/28991/Intel-Graphics-Windows-10-DCH-Drivers?product=80939
    Audio is a little trickier as it depends on whether you need the old legacy HDA driver or the newer UAD driver. It's a bit of a minefield.
  8. kuroidoragon
    14 Oct 2012
    and they are for my motherboard ? just couldnt see my board mentioned there
  9. RedFlames
    23 Apr 2009
    They're not explicitly for your motherboard, but they are for the model of Intel Ethernet controller [I219-V] and for the chipset [Z370] used by the board.
    If those drivers also have a tantrum, then something is definitely not right somewhere.
  10. kuroidoragon
    14 Oct 2012
    ahhhh ok I will download those ones then & install the lan ones for now thank you
