Small Form Factor Does the Zalman Reserator fit on shuttle mounting holes?
Discussion in 'Hardware' started by Atomic, 7 Sep 2004.
  1. Atomic
    Atomic Gerwaff
    6 May 2002
    As title really...
  2. Simonsnet
    Simonsnet What's a Dremel?
    25 Jun 2004
    no it won't. The reserator relies on the mounting cage or standard sized AMD mounting holes.
    I bought it to use in a SN45G. I did actually find that by using the standoffs provided (designed for mounting with A64) in the diagonal holes and stretching the bar a bit you can actually mount it sufficiently.
    It does actually work suffiently. I have actually asked Zalman if they will release an alternative mounting method, but they said that they won't.
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    Grr. How annoying.
    Looks like I'll have to machine some custom brackets then...
  4. Firehed
    15 Feb 2004
    Just use a couple standoffs or insulated screws or something to that extent and use a spare PCI slot cover to make a ghetto bracket. Should work, at least until you can machine out a nicer one.
  5. Simonsnet
    25 Jun 2004
    yeah, that would work fine. Alternatively, you can just get a different waterblock to use with the reserator.
  6. Atomic
    Atomic Gerwaff
    6 May 2002
    Tempted to just buy an Xice CPU block... looks like it'll be the easiest way.
  7. ICDragon
    ICDragon What's a Dremel?
    25 Jul 2004
  8. Simonsnet
    25 Jun 2004
    You interested in buying a Reserator then? I am selling mine as I need an internal setup now.
