Hello, I was want to know if i can install 2 office on my windows, Mean I want to install office 2003 and office 2007 on windows vista 32-bit and make both working fine without any problems or reinstall shits. Thanks very much.
Dude, that makes less sence than most of your posts But it should work fine, just make sure when you install it you dont click override installation, and install 2003, befor you put 2007 on. And as a question why would you need to copies of office?
because I have 2003 and I got 2007 now. So I think that 2007 is cool and speed and auto, But some times I think that 2003 is manual or stock some thing like that. So I think I shoud have 2 of them Thanks
ROFL, No I'm not kidding, Nothing to use in school work else than MS Office... and I was using it from ver 97 So It's kinda the only thing to use.
Office 2007 does everything 2003 could do, and you just have to save it as a .doc (not a .docx) file and it will load into office 95->office 2003 on other pcs
True, but there also is a compatibility pack you can download that lets you read 2007 format in older versions. Computerking, I have both 2003 and 2007 installed on my XP Home machine and it works fine. My wife doesn't want to learn the 2007 menu system, so we just each use our own copy of Office. The only catch is that you cannot have Outlook 2003 and 2007 on the same computer. 2007 will forcibly overwrite 2003. Other than that, you're set.
The university has office 2K3 and 2K7 running together under win XP; so it should be possible under Vista as well. I may ask the IT admin how he got them working together. I personally prefer using 2K3.
200 is sweet. the xml format can be read without any extra files by both office xp and office 2003. A compatibility pack exisits for office 2000. earler versions are not supported. 2003 and 2007 should run together fine on vista, although i'd stick to just using 2007, as as soon as your used to it, all earlier versions seem slow and not very intuitive...
2007 Is awsome but I didn't know that I can save the files with .doc! This is nice! Also IT's faster and lighter. Also 2003 use front page but 2007 use Exprision Web Disanger It's way better but 2003 is like.. Stock one. It's same Xp and Vista I was using the both for 6 months but now I only use Vista and It Run every thing and it's amazing windows really! Thanks I think I will try to use 2007 only, Who knows thanks too much radodrill I'm waiting yuor answer from the It admin in university, as the guys said they will work but HOW! EDIT: You can see the 2003 and 2007 on this photo:
