Memory Does/will it matter...?
Discussion in 'Hardware' started by Jeff Hine, 12 Jun 2019.
  1. Jeff Hine
    Jeff Hine Nothing special
    8 May 2009
    ... if I use this instead of this, in a Ryzen build...?
    It's gonna s**k whale balls if I have to spend an extra £40 as "Ryzen tax"...
  2. Anfield
    Anfield Well-Known Member
    15 Jan 2010
    Links ain't working.
  3. silk186
    silk186 Derp
    1 Dec 2014
    The links are not complete.
  4. RedFlames
    23 Apr 2009
    He's trying to pick between this kit and this one
    Nope [in my limited experience], certainly not with Ryzen 2 [i expect ryzen 3 would be the same]. 1st gen Ryzen was the fussy one.
    Jeff Hine likes this.
  5. Jeff Hine
    8 May 2009
    This...
    Ahh; OK - not been made "as clear as it could have" (to me) that the 'issue' has been negated in any way - Gigabyte are still saying "B3200 is not supported" on one of their 'boards :(
  6. Hardware_Numb3rs
    Hardware_Numb3rs New Member
    21 Apr 2019
    I would avoid that kit, instead you can look for the HyperX Fury 3200 C18 1.2V, or the Sniper X 3600 C19, or, the best DD4 kit you can buy, Gskill Flare X 3200 C14 (high binned b-die)
    Ryzen is picky with memory, and tuning the ram is the first way to gain performance, much more than OCing the CPU, and not all the kits will let you do a good tweak
  7. Jeff Hine
    8 May 2009
    This is starting to feel like an 'overthinking' exercise, at my end... certainly feeling like 1 step forwards, 2+ steps back.
    Should QVL lists be a credible source of reference?
  8. Anfield
    15 Jan 2010
    In general yes, just keep in mind they may not necessarily be complete or up to date, a new bios version may change things, some memory manufacturer may change what chips they use etc after the list has been written.
