!!!!DONE!!!! ««-Twin Turbo­™-»» What the....
Discussion in 'Project Logs' started by Hal, 1 Feb 2005.
  1. Hal
    Hal What's a Dremel?
    1 Feb 2005
    last stuff for tonight...
    mounted the power plugs for the vid card and leds..
    you can see where i have also cut places for the ATX power and a few others.
    here is the psu polished up and the front connectors sleeved.
    i was playing around with an orange fan and added 4 white superbright LEDs... well the outcome was awesome once again. so i might be changing a few things up with the lighting... i have to order some new LEDs now though! haha
    here it is mounted on the rear as i planned it to be... looks great. the mesh gives it just enough cover and lets enough light through.
    rock on till next time!
    i am also waiting for some plexi too, to finish this project. youll see what i have planned!
  2. Visionism
    Visionism What's a Dremel?
    24 Mar 2005
    ok now THAT rocks! Great work on those fans. Much nicer than the old ones I think.
  3. Hal
    1 Feb 2005
    small update for tonight
    started cutting the false bottom so that i could run some wires and things under it. while i was at it, i decided to do a little more with it. check pics to see.
    Cant wait till all the hardware comes in! should be this week! then i can really get some installation and wiring done!
    just a parting shot of how the fans mounted... looked clean
  4. Hal
    1 Feb 2005
    any comments? like the white LEDs better? :confused:
  5. H311R4153R
    H311R4153R What's a Dremel?
    28 Mar 2005
    Those led fans are superb :eeek: . Just realized that orange can actually look very very nice :cooldude: . Once again a very good Chieftec mod.
  6. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I sure do :D How are you planning to mount that plexi to the floor? I'm thinking of doing something similar, thanks for the inspiration :) Infact, our cases are very similar, see my sig ;)
  7. PhatMatt
    PhatMatt What's a Dremel?
    31 Oct 2003
    how are you applying that hex mesh to the plexi on the false bottom? gravity?
    lookin nice, i like the color scheme!
  8. Hal
    1 Feb 2005
    i plan on using the same hex bolts that i will use as standoffs for the plexi bottom. two nuts (hehe) will hold the mesh and hex bolt up and then the rest of the bolt will act as legs to hold that plexi from the bottom of the case.
    i will post pics soon to illustrate that.
    thanks for the comments... i take all the comments and that feeds the mod! from your feedback i take it where the mod can go! thanks all!
  9. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    looks sweetage nice job
    - S
  10. Hal
    1 Feb 2005
    new change... after messing with the orange and white leds... decided to do this and liked this one WAY better!
  11. dpraedan
    dpraedan What's a Dremel?
    6 Sep 2003
    Oh man, this is quite the sick mod. :thumb: I must say, that orange on red looks wicked nice. Never would have thought of that, but it's nasty nonetheless. Reminds me of a Monster Garage episode... anyways, if I could make a suggestion, for the PSU, consider instead switching over to an Ultra X-Connect. I have one and it's the slickest thing you'll ever see. The mirror finish they have on it is phenomenal, and you can get 'em on TigerDirect for $40 for a 400 watt and $70 for a 500 watt, with mail in rebates. Linkies, for anyone who cares:
    500 watt
    400 watt
  12. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    swap the orange blades for the chrome ones ;)
  13. Visionism
    24 Mar 2005
    Still like the orange fan better
  14. linger
    linger What's a Dremel?
    10 Feb 2005
    it looks great!! but don't get an ultra-x psu, get a better psu from a good company. go for function over looks, trust me theres a thread on hardforums talking about one of those ultra-x psu's frying his dfi-sli board. Anyways i just thought i would let you know
  15. nick[x1]
    nick[x1] What's a Dremel?
    1 Nov 2004
    Love the paint, it looks great. The side panel :O SWEET :)
  16. dpraedan
    6 Sep 2003
    Well, it's unfortunate his board fried, but I've heard lots of good stuff about the PSU, especially the fact that they don't peak at 400 or 500 watts, they continuously run at it. A couple of reviews said they perform marginally better than their Antecs under high load.
  17. linger
    10 Feb 2005
  18. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    pwnage :D
  19. mr.X
    mr.X What's a Dremel?
    15 Mar 2005
    very nice colors indeed :thumb:
    for the fans.. I like the chrome ones (ultra) with the orange leds in it :clap:
    as for the psu.. I like them a LOT! I'm also thinking of buying one.
    keep the good work going :thumb:
  20. alonso_bistro
    alonso_bistro I'm just looking
    19 Feb 2004
    good work Hal (i thought i was in my topic :D )
    i prefer the orange fan - but u decide !
