yeah, hindsight is 50/50. i thought of that after i did all the filler work. kind of sucks... oh well. it will be nice though
lots of wire cleaning to do and overall cleaning, some sleeving, touch ups. but for the most part no more large mods, just finish painting the black parts and clear coat it all. make it last! and thats it.
some more pics fixed my messup with teh blowhole (did not do any sanding, just a quick gloss paint job...no need to pull a linear!) still have to do another layer of blue and then the clear coats. after that, installation of the hardware and piece this bad boy back together.
very nice the colors work well together. One tip I see you have a fan controler, If you hook up the blue cathode's inverter to a fan chanel you can adjust its brightness to that of the green on as its a little to harsh at the moment.
Looksreally good man! its nice and smooth and matches! and the colours work really well together damn good job mate
Looks great! I love the gloss black paint, it mixes nicely with the blue. That front intake fan looks nice as well. Keep up the good work
Did you think about turning the rear fan upside down, so that not as much of the cable is on show, or are you going to sleve it? You can see it in this pic
Mmmm sexy. I'm not a fan of the Bio-hazard, of the nuke cases, but you made it look good! Gave me an idea to finish off the side of my buddies case, same idea with the symbol, only raise it on a peice of Plexi, and illuminate it with some LEDs! Thanks for the inspiration!
wow, this has been a long time! got to finish! TA DA!!!! done, no more except trashed turbo! thanks just a quick build for my friend! cheers.
