Disaster Don't stick your fingers in your fan, it might just come off worse!
Discussion in 'Modding' started by Adam, 5 Jul 2002.
  1. TwiSteD LoGic
    TwiSteD LoGic What's a Dremel?
    1 Nov 2001
    meh... i think i beat everyone of us and our adventures with fans... onto pallets full of concrete mix =) Had some genious forklift operator set one down on my foot :cries: :eeek: :cries: :eeek: Everything seemed to be ok, yeah it hurt ALOT, but nothign seemed broken. I thought it was about 2000lbs of concrete there. And after that happened I had to continue to load it onto the truck =( Turns out when I get home the gross weight of the pallet *according to the packing list* was 3,400lbs all on my foot OW!
    Fans are fun, pallets.... they are not!
  2. jamicon
    jamicon What's a Dremel?
    26 Nov 2001
    first i did it on my original AMD tbird cooler, and broke the blade (and took a chunk outa my finger). This was a 5v fan running @ 12v, and it spun so fast that if i left the fan on im sure it would have shaken the heatsink and chipped the CPU (thats another story, ive broken 2), i took off 2 whole blades!
    then i did it on my vid cards 40mm fan, and didnt notice for a while!
    then with my Super Orb which i got to replace the last broken one, i broke the top fan, so being so tall it made the whole thing vibrate running it.
    So i got a Blue orb for the vid card. And lo and behold, it got the finger treatment also :), so i got a new blue orb for it.
    So then, to combat my bad habbit for stopping fans with my fingers, i got watercooling, with a beasty 240v metal bladed 120mm fan from papst. and i would like to state, this thing hurts like **** if it hits your fingers, and it could break them if you tried hard enough.
  3. Pricester
    Pricester What's a Dremel?
    25 Aug 2002
    I read through this post thinking "nah, my case is fine... I'd never be silly enough to hit the fan"...
    Two minutes later, I was adjusting my CD-ROM, and brushed the spinning case fan with my knuckle. Must have jumped about a foot in the air, but fortunately I'd just hit the smooth middle bit.
    Still, it's easily done!
  4. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    One word: fanguard. Or is it two? Too tired to care. I think after the first accident, you would have started putting fanguards on every fan in the system. :eyebrow:
    Glutton for punishment.:rolleyes: :D
  5. George
    George Bah
    14 May 2002
    Ive purposely stuck my finger in loads of fans, but when you do it by accident, you dont half get a shock! lol.
    .icecube
  6. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    Doee something similar, with a screw driver and a thermal take Volcano II, the worst cooler in history, it couldn't keep my old T bird 900 cool in a force 10 gale!!
  7. Angel_of_Death
    Angel_of_Death What's a Dremel?
    9 Apr 2002
    Did that hurt by any chance? :eyebrow: :naughty:
    (putting your finger in a 17v Panaflow)
  8. eroder
    eroder What's a Dremel?
    20 Sep 2002
    Try putting yer finger in one of These:
    from Big Fan
    I've got 2 in my system and YES i'm using custom made fan grill for 'em.
    NO way I'm putting me leeeetle finger in them.
  9. Angel_of_Death
    9 Apr 2002
    hmmm, that'd be good for chopping carrots.
  10. star882
    star882 What's a Dremel?
    19 Mar 2003
    I had something like that happen with a Pentium 3 fan.
  11. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    Funy: did you also stick your nose into a fan? :D
    It is not dangerous to stick your fingers in a fan if you do it from the right angle to the fan blades. Then your finger will just jump around in there. No harm done. I had to check if the PSU fan in my computer was running a couple of hours ago. Being smart as I am, I just jammed a wire in it.
  12. Premium
    Premium What's a Dremel?
    10 Mar 2003
    on the first day i got my athlon i accidently stuck my finger in the fan when i was moving some cables around....those stock fans are sharp as hell! i lost a blade and a small peice of my finger :sigh:
  13. ble81
    ble81 What's a Dremel?
    4 Apr 2003
    Finger in fan???
    I have tested my fans pretty much the same way except I usually touch the very center of the fan and I don't touch the fan blades.
    If it is spinning I can feel it without the pain of braking the blade or hurting my finger.
    Brian
  14. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    Good thing you don't work on planes. Might want to stick your finger in the spinning turbine, to see how fast it's going and all. Although I think the turbine will be fine, you may not be though :D .
  15. Amorphus
    Amorphus What's a Dremel?
    25 Feb 2003
    I have fanguards everywhere. I couldn't put a 92mm fanguard on my 92mm tornado cuz the slk-900's fan clip got in the way, so I hot glued an 80mm fan grill on... I dunno, I guess I just value my fingers. plus the fact that I got more fan grills than I wanted when I ordered a few... (hey! I didnt know they came in packs of two, alright?!)
  16. Gandi69
    Gandi69 Like to get busy wit fizzy..
    17 Jul 2001
    I decided one day to pick off some dust/crap on the heatsink of my Taisol, and in doing so (the PC was on at this time) accidentally stuck my finger in the stock fan shattering a blade in the process. It split my finger nail up the middle, and I can tell you that hurt. Had to replace with sum old stock fan from an old heatsink I had lying around, the thing is though the temps are just the same!
  17. bard
    8 Mar 2003
    I got an 80mm Sunbeam fan yesterday. It runs at about 3000 RPM. During the mounting process, I got my fingers in it all the time, but I never got hurt. How do you do it?
  18. Gandi69
    17 Jul 2001
    80mils are usually fine, as the blades are quite thick. If you wanna see if u can do it try it with a 40 mil or slimline 60mil :D
  19. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    I've been running a 24v 120mm fan pointed right at the open sife of my old comptuer for a while, trying to jeep things cool. I also have the mouse/keyboard right next to it as well. I kept moving the mouse, and getting a few fingers caught in the fan!
    I soon did a gheto internal job :thumb:
  20. bard
    8 Mar 2003
    Hmmm.... I was working on my computer today, and while not looking, I got my finger in the CPU fan. Ouch! Well, luckily my finger nail protected the finger. Glad I didn't hold my finger the other way around... Ok. Now I know what you guys mean. :blah:
