News Doom gets launch trailer, official system requirements
Discussion in 'Article Discussion' started by Gareth Halfacree, 6 May 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. rollo
    rollo Modder
    16 May 2008
    Won't be the first game to end duel core support. Most of the newer engines are designed for more than 2 cores.
  3. Decemoto
    Decemoto What's a Dremel?
    30 Nov 2003
    " Nvidia GeForce GTX 870" - do you mean GTX 970? There was no 800 series.
  4. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    Does it support SLI?
  5. Gareth Halfacree
    4 Dec 2007
    Yarp - typo. I'll go fix.
  6. hyperion
    hyperion Minimodder
    30 Jun 2007
    And then John was a zombie.
  7. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    Does this mean it won't even load on my system even though I played the online beta?
  8. Vault-Tec
    30 Aug 2015
    No idea. Apparently there is a Vulkan patch coming out for it so who knows? We really won't know until people start to complain :D
  9. wolfticket
    19 Apr 2008
    Are we actually talking about "requirements" or just typical minimum specs here?
    Unless things have changed minimum specs are just as much a recommendation as the recommended specs are. It surely (??) won't block you from running the game at all unless there is a something fundamental that requires 4 cores, even if it doesn't (or they think it won't) run particularly well.
