Modding Door molding help
Discussion in 'Modding' started by H4z4RD0uS, 1 Nov 2003.
  1. H4z4RD0uS
    H4z4RD0uS What's a Dremel?
    19 Oct 2003
    ok, i decided to stop grinding and sanding cuz every time i try, i **** up my cut. so im getting door edge molding. can i get it thin enough, yet big enough to cover the grey marks near my cut?
    and do i apply it before or after i apply plexi? if someone can give me a good guide, I would apprecitate it :hip:
  2. diskreet
    diskreet What's a Dremel?
    1 Oct 2003
    If you give us pics we can answer that and understand it a bit better.
  3. Lithium
    Lithium super spunk
    26 Jul 2002
    are ya doing something like
  4. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Ahh Lithium, when did you finally get the door done.
    Sorry for off topic sort of
  5. Dremel
    Dremel What's a Dremel?
    27 Oct 2003
    u can get it many places, i don't know where but there are many sizes so you should be fine.
    lithium randomly shows the finished door..
  6. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Check automotive stores. My last case used lots of chrome window molding (which looked realy sweet), and it nicely covered up the piss poor job I did in cutting the window and fan holes (little recommendation on using molding w/ fan holes: fan screws suck, go for machine bolts w/ nuts; 3/16" diameter, 1 1/2" shaft works best (4.75mm x 38mm)). Getting back on track....the molding was 1/4"/8.6mm thick, and provided the cut isn't too rough, it slips over sheet metal fairly easily (just take your time with it and use something like a screwdriver to wedge it; forcing it in place will scratch it up, which makes it look so un-1337).
  7. H4z4RD0uS
    19 Oct 2003
    yah, i use my window molding and it looks nice, but i dont think i can stick my plexi on with silicon due to the fact one part of my molding sticks out cuz of a curve on my design
