Cooling Dothan + fridge....
Discussion in 'Hardware' started by Highland3r, 1 May 2006.
  1. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    ... equals.... A rather nippy CPU! Dothan at 2.8ghz was pretty quick, but these chips LOVE winter climates. So, strap a Gray Mole modded Mach1 to a Dothan and what happens, well the CPU gets a bit chilly (-37 to be exact) and begins to giggle with glee.
    Once his toes are covered with frost, the real monster within is unleashed. Down and -35 deg (real CPU temp) with a healthy 1.65v up its rear the Dottie 750 managed a healthy 3.25ghz running on a 13* multiplier and 250FSB.
    With this extra CPU speed, and another Gray Mole special on the GPU the 6800LE (modded to 16 pipes) has smashed the previous 01 WR by 1300 points, first LE to break 34 and 35k, settling for now at 35051
    It's not an awsome CPU, but 3.25 ghz isnt bad, a little more time and 3.3 should be do-able, with a more favourable FSB too.
    Superpi ain't bad either ;)
  2. XLGlobetrotterXL
    XLGlobetrotterXL Banned
    29 Apr 2006
    WOW, 3.5ghz.... I can only get 29seconds out of that test :eek: well done to you.
  3. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    :D Nice as I said before
  4. hitman012
    hitman012 Minimodder
    6 May 2005
    Very cool stuff (bad pun, sorry). Congrats on the WR :D
  5. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Congrats :)
    What do you mean, "it's not an awesome CPU" ?!?
  6. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    congrats :thumb: and... wow :D
  7. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    nicely done mate!
    cant believe you still managed to squeeze more out of that dothan! still one of the quickest cpu's about, despite being old now (well in terms of technology!)...shame I have to sell my dothan rig... :sigh:
    any chance of getting a higher fsb, with a lower multi or does it just not boot then?
  8. OldY
    OldY What's a Dremel?
    10 Mar 2006
    :rock: Wow thats gob-smackingly cool :rock:
  9. Highland3r
    25 Jul 2003
    Can run up to ~ 270 FSB with the BH (more with more volts hopefully) but CPU isnt quite stable up there. With more voltage (CPU) it should be do able though.
    Mach's not quite cold enough to get the most out of the CPU really, it needs the Chilly1 tube sticking on at some point.
    It's been interesting to see the speed increase with various cooling though, 2.65 benchable stock air, 2.85 under water and now 3.25 under phase.. Maybe 3.4 will fall under DICE??
  10. felix the cat
    11 Jan 2002
    I think you have hit the nail on the head there...when they first came out and I saw some overclocks just on the standard air cooler, and a couple under water, it showed just how big the potential of these dothans are, but I also would have to say it takes a nutter like you to get the most out of it...is your mobo vMod(ed)?
  11. Highland3r
    25 Jul 2003
    Nutter? No... this is pretty tame compared to others.
    Yea, vDroop, and vCore mods. Feeding her 1.65v atm for 3.2ghz, run 1.7 for 3.25, so hopefully pushing towards 1.75 should give 3.3.. Need VCCA mods to the CT-479 sometime soon too, which should help things out a bit.
  12. Hiren
    Hiren mind control Moderator
    15 May 2002
    Go go Andi!
    Very nice mate
  13. Highland3r
    25 Jul 2003
  14. Shadowed_fury
    21 Nov 2003
    Nice work Andi. :D
