Downloaded the new A3 units and pdd has dropped to 150, from 2k:(
Discussion in 'bit-tech Folding Team' started by GingerFox, 3 Apr 2010.
  1. GingerFox
    GingerFox What's a Dremel?
    15 Nov 2009
    Bassically, why?
  2. jimbo90210us
    jimbo90210us What's a Dremel?
    17 Mar 2010
    What work unit is it you are going through?
    I had a 6040 that took 22 hours to do, if the monitor you are using has not been updated with new projects it could be telling you porkeys.
  3. Tesla effect
    Tesla effect AKA ZombieKiller1
    24 Jul 2009
    I guess your still using Fahmon? You should understand that the a3 projects points allocation is bonus based. Install HFM.net, configure your clients in the the same manner & select the option that calculates your bonus then you will see a more accurate PPD estimation.
    http://forums.bit-tech.net/showthread.php?t=181726
  4. Tesla effect
    24 Jul 2009
    6040 is new, I've not seen one. Did the score compensate for the longer completion?
  5. jimbo90210us
    17 Mar 2010
    Yes I think I got about 8800 points for it (worked out from the SMP2 points calculator).
    Base points are 1395 from what I can remember from looking it up this morning whereas most of the other a3 projects are 450 - 500 ish.
    They are supposed to take about a day for a normal i7 and a day to day and a half for a Core 2 Quad.
    http://en.fah-addict.net/news/news-0-197+smp2-project-6040-released.php
  6. Tesla effect
    24 Jul 2009
    Cool, so in my case with a Q6600 it will be probably score 6k which is about the same as the 6011-6025 projects. I assume you completed in 22 hours with an i7?
  7. jimbo90210us
    17 Mar 2010
    i7 930 @ 2.93GHz and -smp 7 flag with native Ubuntu 9.10 2.6.31-20.
    I think it got 8613 points but will know for sure when it pops up in a few minutes on EOC stats. Takes a bit of time to upload and eats a fair bit of RAM, not as much as bigadv though.
  8. Tesla effect
    24 Jul 2009
    Interesting link. The a3 core is clearly a step closer towards the bigadv WUs. When they are fully migrated from the a2 core I think I will build an i7 930 rig myself. Hopefully this will co-incide with new Ubuntu release.
  9. Lehmann
    Lehmann What's a Dremel?
    18 Dec 2009
    I did a 6041 in about 16 hours 10,000 points from what i remember
  10. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Don't forget you will need to generate a key to use on the clients for getting the bonus on the A3 and BigAdv projects!
  11. rojw13
    rojw13 What's a Dremel?
    28 May 2010
    Is it only the smp client that can get the A3 units? (none of the gpu clients etc) I have to do ten of these to start getting bonus points (after passkey was entered) ?
  12. Tesla effect
    24 Jul 2009
